List of MFWD models?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: List of MFWD models?
    Posted: 05 Apr 2013 at 8:38am
What AC models were offered with some type of FWA or MFWD as an option in large numbers?  Could you get all of the 5000, 6000, 7000, and 8000 series with this option?  Anything else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 8:40am
They all offered except 7000s they didn't offer mfwd
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 9:50am
Wouldn't a 185 or 190 be neat with front wheel assist. I've seen a WC with it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 10:50am
How did they make the WC FWA?
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 11:09am
Although the early 8070's were not offered MFWD until A C was confident the components could handle the horsepower. I believe it was late 82' or early 83' when they made them available.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 11:13am
Also there was 100 220 MFWD's made. Allis also piloted a Hyd FWD on the D-21. 10 units were built and all but one were brought back and switched back to conventional 2wd front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 1:16pm
Dean there were two WC four wheel drive pictures either in old Allis news or Allis connection magazine I don't remember. The one had a truck type front and they put a Ford truck transfer case were the disconnect for rearend is. I heard the splines and shaft are the same size like it was made for it. Then I'am sure they had to get gearing right. The other one had same size fronts as regular rear WC's and I think it was more of a center articulating with two WC rear ends. Maybe I can try and find the pictures but I've got alot of magazines to look through.
T.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2013 at 8:40pm
I saw a 7045 in NNY with some sort of front wheel assist. I didn't have time to stop and check it out. I don't know what kind of aftermarket setup was on it but it sure looked mean.
T.J. View Drop Down
Too be clear on the 8070 mfwd models. The components they were checking to see if it would take the horsepower was the 8050 mfwd drivetrain. Most 8070 2wd tractors used 7080 gears and go slower than 8070 mfwd's. They evidently didn't think there would be enough demand to make a different front end gearing to use the original 8070 2wd rearend.
Edited by T.J. - 08 Apr 2013 at 6:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2013 at 8:46pm
Originally posted by KGood KGood wrote:
<FONT style=": #000000">Dean there were two WC four wheel drive pictures either in old Allis news or Allis connection magazine I don't remember. The one had a truck type front and they put a Ford truck transfer case were the disconnect for rearend is. I heard the splines and shaft are the same size like it was made for it. Then I'am sure they had to get gearing right. The other one had same size fronts as regular rear WC's and I think it was more of a center articulating with two WC rear ends. Maybe I can try and find the pictures but I've got alot of magazines to look through.
I'm always amazed at what people can do. If you get time, I would love to see pictures of the conversion.
