8 bolt 32" rims where to get?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Topic: 8 bolt 32" rims where to get?
    Posted: 22 Mar 2013 at 7:35pm
Im looking to find a set of 21x32" rims to fit my D17. Is there a combine that used this size and bolt pattern? Any info would be great
Thanks guys!
Tyler
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 8:11am
You can buy new 32" rims without centers, then find used MF 38" centers to adapt to the rims. MACK
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:46pm
Some of the casein tractors had a 8 bolt 32 inch rim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 7:45pm
Would you happen to know which model or models?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 7:54pm
I honestly forget the model but I'm pretty positive it was 8 bolts it was a tractor that are township had about 50 horsepower early 90s is when it was built I believe the wheels were similar to some fords how the centers bolted to the rims I'm thinking it was a 21?? But I could be way off on the model number to be honest
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 8:33pm
After looking a little a 1494 has 8 bolt centers but its 34 inch rubber but the 1394 was offered with 30 inch so maybe that was the model I'm really not sure though from photos it reminds me of the townships tractor
