H-3 Parts Info. - Share Item - Aftermarket Parts |
orangeman
Topic: H-3 Parts Info. - Share Item - Aftermarket PartsPosted: 05 Mar 2013 at 3:15pm |
Guys: Wanted to begin a useful thread on H-3 aftermarket parts and reference numbers:
To get the ball rolling here are a few that might be of use. 1. Napa Hose 7096 - fits oil bath air cleaner outlet to carb. May need to cut slightly to adapt. 2. Napa Balkamp 715-1115 Button Head Grease Fitting. Fits the bottom truck rollers so that you can use your 90 Weight Oil to keep the bottom end nice and lubed. Hopefully more to come. Anyone else with good aftermarket info. please chime in. Thank-you...Orangeman
ac-mike
Posted: 09 Mar 2013 at 6:07am |
Speer supplies the seat back and bottom cushion
orangeman
Posted: 09 Mar 2013 at 6:36am |
AC-Mike: Great Information I need a seat and back so will check that out. I was going to make my own using 3/4" plywood then take to a upholster shop close by.
There was a thread on here a month or so ago on the seals for the transmission case and final drives. I am going to go back and search that to see if there are any useful part numbers. Appreciate the info! Orangeman...
