H3 w/1081 Angle Dozer -Need Cutting Edge
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: H3 w/1081 Angle Dozer -Need Cutting Edge
    Posted: 23 Feb 2013 at 5:03pm
Guys:  Who sells cutting edge end sections and the blade cutting edge?  My guess is that New Holland does not carry the cutting edge.  Maybe I should check Caterpillar?
Anyone here replaced their cutting edge on the dozer blade for an H-3?     Thank-you for any advice.
Orangeman
Edited by orangeman - 10 Mar 2013 at 5:09pm
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2013 at 10:33pm
I rebuilt my shuttle clutch and part were furnished by Illini Construction Parts, an advertiser on this site. The plugs for the steering clutch compartments are 55 gallon drum plugs. The track guards will have to be purchased from a wrecking yard or fabricated. all the instruments are D-15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 4:18am
Ages Cat:  Thank -you for the info.    That helps alot.
Appreciate it!
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 3:56pm
IF you put those bung plugs into the case - be sure to drill a few 1/4" or larger holes in them or the next thing will be you will ask what to do about waterlogged and rusted parts in that case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 4:43pm
Coke:  Excellent idea, hope that mice can get into a 1/4 hole.  Danged they really mess up the inside of a bull pinion housing.   I got a heck of a laugh out of Dozer's post a while back about the tensile strength of mouse pee!!!
This page was generated in 0.221 seconds.
