allis 2row planter pictures
troyl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyl Quote  Post ReplyReply Direct Link To This Post Topic: allis 2row planter pictures
    Posted: 21 Feb 2013 at 9:58am
 almost done with the painting. thought i would share as i like looking at other peoples.
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyl Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 10:12am
 this is the plate that is in the seed bin. is this o.e.? it says lustran b-soy 3x so i'm thinking it's a soybean plate. i would like to plant corn and would like to find a diff. plate. i looked on ebay and the ones i found that look like these are for jd. would they work? it is 6 7/8 inches across. thanks for any help.  Troy
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 10:26am
It is a soybean plate. Corn plates are common, lots of diff sizes though. Lookup Marshall Machinery on ebay (new2youtractorparts) and ask them what they have available. They have a lot not listed and they are pretty good on pricing. They will probably be listing a bunch soon, now that planting season is just around the corner, it might be good to beat the crowd.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 10:28am
Looks nice. I know where one of them are that I have been thinking of buying.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 11:11am
Troy. your drill planter looks fantastic. would bet it will plant 150 plus bta for corn and 50 plus bta beans. thanks for the memory.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyl Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 6:34pm
thanks for the kind comments. i ordered a set of corn plates off ebay last week that are for a jd but looked the same. if they don't work i'll try new2youtractor as listed in one of the above post. now that i know how to post pic. i'll start sharing some of the wood dragging photos with the d14 later. thanks again!       Troy
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 7:41pm
Those are John Deere plates that you have in the picture.  Those white plastic inserts that go inside the plates are made to allow the use of John Deere  plastic plates in an Allis-Chalmers planter.  If you go to a place that sells seed corn, they probably have many different sizes of plates that they would give you for whatever corn you bought.  There are many different plates for corn, there isn't just a "corn" plate.  Most seed corn will list the suggested plate to use on the tags attached to the bag.  I suggest that you use one size larger plate than is usually suggested for best results.  Here is a video of my father planting corn with his two row AC planter.    I can probably answer most questions you have about your planter.  Also, here is link to Lincoln ag products that have all the different plates and the adapters to use the john deere plates in an AC planter.  http://www.lincolnagproducts.com/
[TUBE]http://youtu.be/43c1aQGaC5w[/TUBE]
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 8:22pm
troyl...that yellow plate pictured is a john deere plate
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 8:24pm
you can still buy them new direct from the factory in lincoln, ne. there is a price list on line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyl Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2013 at 1:36pm
thanks for the info. DanD what sprockets should the chain be on?  i'm just using it to plant my food plots (about 3 ac.). i set it as wide as i could 42" and am planing to plant a row in the middle of each pass to end up with 21" row spacing. Or is that a bad idea? also thought about dragging in some soybeans before i plant the corn. thanks .  Troy
shattercane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2013 at 1:49pm
I have the option to buy one of these as well....the owner and I are trying to figure a price out...it looks about like what you started with. Does anyone have a price that would be fair to offer? I haven't seen any others around this part of Kansas and don't want to low ball too much although I don't want to overpay either.
29 L Case, 37 CC Case,40 A-C allcrop 40, 43 B Allis Chalmers, 50 DC Case, 54 WD-45 WF, 67 190 Gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2013 at 1:50pm
Hope you don't mind me hi-jacking your post troyl :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2013 at 3:34pm
cane. around central Ohio would suspect you will have to pony up $800 to 1200 if the fertilizer boxes are useable and row markers are in tact. its probably a given that the shoe is either marginal or not usable but that can be fabricated for another $150.00.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 7:37am
Well, if you don't have a manual you'll just have to play a little until it's putting out a seed at the spacing you want.  On my father's planter, I believe he has the chain on the largest sprocket on the drive axle and smallest sprocket on the shaft that drives the planter plates.  With 16 cell plates that gives one seed as you turn the press wheels about the distance from one spoke to the next.  Just play with it and you'll get it close enough for your purposes.  You may have different sized sprockets on your planter than what my father's planter has, too.
I found this picture of my dad's planter and you can see the sprockets on the rear and which one he uses.  I know he uses the smallest sprocket on the plate driven shaft which I think is either a 7 or 9 tooth sprocket.
Edited by DanD - 24 Feb 2013 at 7:43am
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 8:41am
Here's my two row planter. I plant corn with the chain on the biggest back drive sprocket and the chain on the 7 tooth front driven sprocket it drops about 9" apart. In this shot I had it on the middle driven sprocket and it droped about 12" apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote troyl Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 6:06pm
thanks for the pictures. it wont be long till we get to use them.  Troy
HANIMAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HANIMAL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 11:11am
I have one of these AC 2 row planters. Anyone know where I can get the chain that drives the sprockets for two top buckets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 11:32pm
Start your own thread.  You'll never get answers on this one...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 5:00am
flat chain? I gots a bunch of that in dif sizes, all used, but in useable condition. I may also have some new somewhere
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 7:24am
Never Say Never.
Dooohhhh!!  I just did.
