HD6 final drive bearing crossreference
Rx7man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Topic: HD6 final drive bearing crossreference
    Posted: 19 Feb 2013 at 12:02am
Well, the outboard idler shaft bearing on the HD6 packed it in on me, and I'm looking for a bearing number from that bearing before I start taking things apart, the Allis part numbers are 51437 and 51438... does anyone have one around that they can look at and give me a timken or SKF number from?
I think it died from lack of lube... they had a bunch of grease in the final drive because the seal was leaking, and it was about -10C when I was using it, so the grease probably didn't flow enough, even though there was oil in there as well.  It will jump the teeth if I put any power or brake on it, and the brake pedal pulsates like hell too... With any luck, it didn't do too much damage to the inner bearing.  Has anyone replaced this bearing alone before?  It looks possible to do if I slacken the track, wedge something in the rear sprocket, and back it up a little in order to lift the track up enough to give me some clearance to work, from there, assuming the bearing hasn't welded itself, I should be able to get it out.  As far as heat goes, the casing got to about room temp before I noticed something was wrong (it was just warm enough to dry the casing off)... I had worked it for about 45 minutes or so.
If anyone has any tips, let me know... and if you're a person who doesn't mind text messages, my number is 778 549 109three.
Thanks all!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 5:29am
You need a puller for removing the outbord bearing cage ass and if he jump when
you use the brake you better removed the bottom final drive cover and check inside for pieces metal before more damage
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 9:09am
I think you are talking about the outboard bearing on the final drive. The cup is link belt 3HB94-0 I can't read the number on the cone. I posted pictures when I replaced this bearing in December 2012. There are 3 bearings on the shaft. The problem you discribe involves more than one bearing. You will need to split the track, move the truck frame and remove the sprocket to get at the problem. Sorry for the bad news.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 9:20am
There are 2 posts you should look at "Dozer restoration has begun" 11 February, 2013 and "HD6G final drive seal" 10 December 2012
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 3:33pm
Your lucky - when that bearing goes bad - a split open case in the area is the outcome.
As that bearing carries to full torque of the tractor to the first reduction gear of the finals.
 I have looked at several HD5 machines with broken cases because of that bearing failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2013 at 12:54am
Just to be clear, it's the idler shaft outboard bearing, the one right behind the bearing cap, the main final drive bearings are good.  I will be pulling the bottom cover off when I get to it.
From what I feel, I think the tapered needles fell out of 1/2 of the cup, and when it gets to that spot, the shaft lifts, then the good ones come around again and push it down, where it engages.  I'm not going to guarantee that the inner one is good, but I'd like to get the outer one installed, give it a test, and see what comes of it, meanwhile perhaps I'll look for additional parts since I probably will need them sooner than later, but at least it'll be mobile.
Now as for removing the bearing behind that cap... It looks like the outer cup should come out pretty easily unless it spun and galled itself to the housing.. Unlikely, the casing temp didn't get above room temp... Now the inner race.. is that pressed on to the shaft?  I wouldn't see a reason to as the outer bearing cup should hold it against  the large part of the shaft...
And for shims... you think it may have been incorrectly shimmed before and that could be a root problem?  should I reassemble it with same shimming?  I couln't imagin anything having gotten tighter...
Thanks for the help...
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2013 at 11:30am
new bearings require different shims. be sure not to get it too tight. i was always taught a little loose is better than a little tight. if you need to get the inner raced out, i weld them in the echter and let them cool and the about fall out. since you have everything else still installed, try heating it up with a torch and letting it coo and it should be easier to get out. the bearings are pressed on the shaft. if i remember right, the shaft is drilled and tapped so you can put a slide hammer on it or a puller and pull the outer race out with the shaft. be sure to count the needles and get them all because one of them going through your gears will be bad. very bad. i have some shafts and gears from a hd5 which should be the same if you need them. good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2013 at 12:30pm
You are talking about the final drive intermediate shaft bearing.
I thought you were talking about the final drive outboard bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2013 at 11:37pm
I'd like to try just replacing the outer bearing for now, if I can do it without taking everything apart, if it fails again, I know the inner is gone, and I'm going to have to take everything apart anyhow... I'll just be out the cost of a bearing for the trial, but considering how major a deal it is to take the track, etc off, I figure it's worth a try.
you think it's possible to take both halves of the outer bearing off without taking the drive sprocket off?
DadsDozer, if you have the gears accessible, you think you can see if you can find a bearing number for that outer idler shaft bearing?
Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2013 at 5:51pm
i will see if i can find it asap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2013 at 9:35pm
I didn't realize it was a doublereduction final drive... the failed bearing is the one from the steering/brake clutch shaft... the top one.
I took the cover off, a bottle jack lifted the track enough to be able to, and the bearing was totally gone. gear looks OK from what I see.  The biggest issue I see is that the inner bearing race ground the outside race seat a bit, but not all the way out to the edge, there's still lots of good meat there for the bearing, but it concerns me that the shaft was able to move inward about 1/2".  I have the manual, but it just shows each assembly individually, and I have a hard time understanding how that shaft is driven... From what I can see, there's a hub on a tapered spline on the inside that holds the clutch/brakes... Now.. what would cause the shaft to be able to move inward that far.  The shaft, without the bearing holding it in place on the outside can move around a lot.. could it break the hub?
I got the part number from  the bearing on the opposite side (MR120), but my bearing dealer says there should be a second part to it.. like MR 1209TV or something, but I certainly didn't see that on the bearing
If I could get an accurate shaft size, that would help... Also, I believe the bearing can be separated (outer and inner), which one holds the rollers?  Does the inner race get pressed onto the shaft first, then the outer race on top of it, with the rollers? Or is it inseperable, so that you need to put both in at the same time
Remember that I'm looking at the topshaft now
dadsdozer... thanks, Really appreciate it... you want another Cub?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2013 at 12:55pm
just looked at my parts book. there are 3 bearings that hold that shaft in place. all 3 are straight roller bearings, not tapered bearings. the shaft is allowed to move in and out a little. i believe there is no inner race to them as they ride on the shaft. i will be at my parts storage tomorrow and will look at the bearing numbers and shafts and take pics if you wnat them. you do have to remove the steering clutch to remove the shaft. not a bad job if the brake band pins come out. there are holes with plugs in the outside of the rear housing to put a 1/4" bolt in and pull the pins from the brake band actuator. if you need parts, let me know and there are others on here that have parts also. you want to fix it now before it gets worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2013 at 7:59pm
i checked my stock today and learned something. the bearings do not ride right on the shaft, they do have inner races. i need to wash them to get the numbers. i will also pass along the seal numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2013 at 7:43pm
Thanks a lot, I can't remember the book showing 3 bearings, but that's possible... I have a full manual for an HD9, and a parts book (with some exploded views) for the HD6.
Thanks a lot, it sounds like I can finally get the bearings ordered
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 8:35pm
Any luck getting part numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 10:14pm
SORRY IT TOOK SO LONG BUT HERE THEY ARE:
BEARING CLOSEST TO THE STEERING CLUTCH: BOWER M1212E BEARING
        MR1212  RACE
CENTER BEARING: BOWER M1212GE BEARING
                                        MR1212 RACE
THIS BEARING THE SAME AS THE FIRST EXCEPT IT HAS A SNAP RING ON THE OUTSIDE
BEARING FURTHEST FROM THE STEERING CLUTCH OR OUTER BEARING:
BOWER M1210E BEARING
            MR1210 RACE
SEAL FOR STEERING CLUTCH COMPARTMENT TO FINAL DRIVE: NATIONAL 55004K
        OR TCM 27373TA-H-BX
SEAL FOR STEERING CLUTCH COMPARTMENT TO RING AND PINION: NATIONAL 415449
THE BEARINGS DO HAVE RACES PRESSED ONTO THE SHAFT AND A SNAP RING TO LOCATE THE OUTER BEARING. THEY SHOULD STILL BE AVAILABLE. LET ME KNOW IF YOU NEED ANY OTHER NUMBERS. GOOD LUCK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 10:55pm
Thanks so much, I'll get them ordered, I think that'll about do it, I'll let you know how it goes... don't hold your breath though, might take a month or two to get to it
Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 1:59am
Well, I got the parts, and got them installed today, was a bit of a chore to cut out the old inner race, but it went back together... We'll see how long it lasts now...
special thanks to Dadsdozer for the part numbers
BTW Dadsdozer.. Message me with what  you'd want for the upper gear assembly, with bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2013 at 12:59pm
So is it all working good now ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2013 at 9:35pm
I haven't run it yet, I'll find out when I have to run it if it's all good... the telltale will be if the left brake pulsates
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rx7man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2016 at 11:44am
Thought I'd update this.. no, it's not all good, the inner bearings are gone too I think.. I only moved it a couple feet since I don't want to bugger the new bearing.. I haven't had the courage to take it apart and see how involved it is to get the steering clutches out...
I'd also like to add that the MR1210E (outer) bearing is a LinkBelt bearing, which may help someone find a source for them..  Perhaps the inners are also available through LinkBelt.
This page was generated in 0.850 seconds.
