HD4 wont move
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: HD4 wont move
    Posted: 14 Jan 2010 at 7:01am
Uncle has an HD4 that works great, except after 10 minutes of running it will stop moving in foward or reverse until it cools back off, then it will move for 10 minutes again. We havent had a chance to look at it yet, but was wondering if anyone ran into this before or has any ideas what too look for
1968 D15D,1962 D19D
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2010 at 11:18am
Sounds like a torque converter problem.
Are the fluid levels up? Does the oil smell burnt?
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2010 at 12:45pm
i can help 989 379 2721
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2010 at 4:13pm
Clutch pack in the fwd/rev worn or hyd pressure low to hold clutches.
Get info to find hyd pressure for the system. also there is a filter in the system and a screen on intake.
 On mine the spring in the fwd/ rev valve broke on one side of valve body and the slide valve would not move into position to allow oil to flow to clutch pack. Replaced the spring and worked fine.
Edited by Coke-in-MN - 19 Jan 2010 at 9:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 7:24am
Thanks guys. I will let you kow what we find when we tear it down
1968 D15D,1962 D19D
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 12:14am
Don...You ever find you problem source?   Thanks....Dale
