"c" front rims on a wd will they fit?
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Topic: "c" front rims on a wd will they fit?
    Posted: 12 Feb 2013 at 5:59pm
will the 5 bolt rims from a c fit a wd? also are they strong enought to stand up to using them on a pulling tractor
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 6:41am
They won't, smaller bolt pattern and center. I have looked into it.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 7:27am
i cut the centers out of a 15 inch mini spare and a junk  wd rim is double step then u trim them down a little and theywill drive in the minispare rim weld them in there plenty strong u can run 450 by 15 tires will lower front end 2 to 3 inches
L Hud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L Hud Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2013 at 7:15am
The rims from a RC will work. Finding RC rims will not be easy. Hope this helps.
