715-B Backhoe Filters
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: 715-B Backhoe Filters
    Posted: 11 Feb 2013 at 8:31pm
I will be changing fuel, hydraulic, air and engine oil filters for the first time soon. Would anyone have a list of filters and their part numbers? I will be crossing them to NAPA. Also where can you buy parts for the machine? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 9:29pm
PH8A engine oil filter . Fram C1191A fuel filters (2) air cleaner elementA-B1K1274309
KIT,AIR CLEANER ELEMENT
https://www.allpartsstore.com/Search.htm?CategorySeq=B&SelcBrand=AC&SelcMachn=INDUSTRIAL/CONSTRUCTION&SelcModel=715B&SelcSectn=E&SelcSubsc=E132
http://www.allischalmers.com/forum/forum_posts.asp?TID=30944&title=allis-chalmers-715-backhoe
Edited by Coke-in-MN - 11 Feb 2013 at 9:34pm
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 9:52pm
You know much about 710C loaders Coke?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 12:16pm
Unfamiliar with that machine - but open to learn .
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 12:31pm
I am looking for a 710C. New Zealand may be a bit far to move it however. I have a brocure and service manual and have looked at one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 1:16pm
Was looking for info on it and found just mention of AC 710C -714C - 715C listed in same ad .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 7:47pm
I have not been able to get much info on them, just that they were available with three point hitch, which for me, would be a very favourable feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2013 at 10:00pm
The tractor is equipped with loader, 3 point hitch, hydrostatic PTO, 200 Cu. in. AC engine, not very many produced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 12:58pm
I had seen a add for a 714B which looked to be the same as a 715B - without the hoe but with 3 point or drawbar draft equipped. So had full loader and frame and such as the 715B just less the hoe hardware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2013 at 9:05pm
Thanks for the filter information. I believe I have all the correct NAPA filters now, but can't be sure until I change them out. I'll post the numbers here after I do. It appeared that the hydraulic filter canister underneath the machine had 4 bolts holding it together. I don't have a filter for that yet. Anyone have any experience with that one? Where can you buy parts for these machines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2013 at 9:41am
MINNPAR - Mpls MN - they have a web site - also New Holland dealers may be able to supply some as it falls in between Construction and industrial .
 Herc-U-Lift in MN and ND handled the units as well as the forklift units based on the similar designed tractor.
 It has been a few years since i used Herc-U-Lift but their shop foreman and guys in the shop were a real help in information on machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2013 at 4:12pm
Thanks for the info on 710C and 714B Curtis and Coke. I,m guessing the only significant difference would be the engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2013 at 5:12pm
I have been working on two Allis forklifts and have been talking to the Herc U Lift guys in the shop and at the parts counter. They are  top shelf guys who know the machines and are not afraid to help you. I would recommend them to anyone.
robleclerc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robleclerc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 10:57am
hey there..are u still online?
Post Options Post Options   Thanks (0) Thanks(0)   Quote robleclerc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 10:58am
I'm looking for coke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:25pm
can send a PM or ?
Lurking somewhere on here every day - just miss some thing s
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 7:43am
A 715C is the same as a 715B with the exeption of the engine. 715 and 715B have the 236 Perkins. The 715C has the A-C 200 cu.in. 433 T engine. Same engine is used in F combines and 6000 series tractors. I think there were a very few CDS 715D's that were Cummins powered.  A friend has a CDS 708 D forklift with a Cummins.
I've got my first 715 in 1977 and traded for a 715B extend-a-hoe in 1987 and still have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 8:08am
Few years back was talking to dealer in WI - said every 715D he sold people wanted the 715B back - not happy with the CDS machines .
 When  IR bought CDS they dropped the backhoe line but kept the loaders and fork trucks for a few years .
This page was generated in 0.805 seconds.
