D17 Tie Bars Ideas?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Topic: D17 Tie Bars Ideas?
    Posted: 11 Feb 2013 at 12:29pm
Need some ideas for a set of tie bars on my d17. I need to get around the brake and clutch pedals. Thats whats holding me up on them. Maybe if id go from the fender mount bolt holes on the axle tube? I need some ideas! Pics would be great.
Thanks for the help
Tyler
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 12:55pm
I was thinking of using the two bolt holes on the inside of each final drive. I believe they were for cornpicker or sickle bar brackets. I was also going to try to connect across.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 12:57pm
I would do that but im prolly going to rotate the finals back. So i dont know if that would work or not. But thanks for the ideas!
