HD11 FILTERS
Argo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Topic: HD11 FILTERS
    Posted: 03 Feb 2013 at 5:47pm
Does any one know what filters are needed for the 1954 hd11 buda engine both oil and fuel?
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2013 at 6:38pm
All HD11 tractors use the same oil filter- I use Wix- 51133, you could cross reference from that.  Fuel filters are different on the older models, I would have to look it up...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2013 at 6:48pm
Allis fuel filter numbers for old HD11- 74055563 and 74056633
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2013 at 8:00am
Is this (fuel filters) a Wix number also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2013 at 7:48pm
Try this site, they can come up with all sort of Baldwin filter for our tractors, then interchange that number to Wix or Napa, if it won't interchange I order from Baldwin Online.
These are the numbers I looked up quick for a HD11:
NumberQualifiers
Lube P20-HD
Clutch B253
Steering PT265
Fuel BF962
F-F Lube Ele. P20-HD
B-P Lube Ele. C704-L(500 Size);
B-P Lube Ele. C750-E(750 Size);(74059343)
Hyd. PT543 KIT(70647255)
Hyd. PT48(Dozer);(70625780)
Trans. P80-HD(74372517)
Steering PT265(70631828)
P. Fuel Sock F916-C
S. Fuel Ele. PF906
Air PA639(70622893)
Tube-Type Air PA1775(70638731)
Tube-Type Air PA1806(70644042)
Edited by DMiller - 05 Feb 2013 at 7:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2013 at 6:43pm
Fuel filter numbers I posted are Alllis Chalmers part numbers from parts book.
This page was generated in 1.004 seconds.
