D-12 renovation |
Marlyn nwia
Silver Level Access
Topic: D-12 renovationPosted: 11 Jan 2010 at 1:51pm |
I am attempting to renovate a left fender of my D-12sIII. Does anyone know if there is someone who manufactures and sells the supports for the D series fenders? Does anyone reproduce the entire fender for a D-12? Marlyn nwia |
David(Stockbridge)MI
Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Posted: 11 Jan 2010 at 2:34pm |
No one I know of makes replacement after market fenders for the D10, D12, D14 or D15. Steiners has them for D17 & D19 but from what someone on this site said they are poor quility. You should be able to make the brackets from flat stock and conduit or angle iron depending on which brakets you need.
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 11 Jan 2010 at 6:57pm |
tried to get made for 3 yrs..no one would even quote them was good order also i thought
snowman(MI)
Joined: 12 Sep 2009 Location: Sand Lake, MI Points: 385 |
Posted: 11 Jan 2010 at 7:40pm |
Try searching some of the tractor salvage yards. I had to replace a couple on my D-10 series III fender rebuild and ended up finding some old bend D-series fenders that I drilled out the spot weld and had to shorten (from D-17) , weld together and then to the fender. One way of doing this, just need to find a bend donor fender that isn't worth much to the salvage man.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 12 Jan 2010 at 6:08pm |
I had to fabricate the rockshaft supports and bush the rockshaft on my D12 rehab. The seat needed extensive repair to the rods/bushings, so have installed an aftermarket seat. Have yet to locate affordable fenders, so next summer will have some fabbed up that are similar to the 620/720 fenders. It won't look original, however, it will run and work just fine. Will post some pics of it when the weather warms up a little more.
acd21man
Posted: 12 Jan 2010 at 7:34pm |
does any body make hoods for d21 or fixes them
need help
pineyjd
Joined: 12 Sep 2009 Location: Southern NJ Points: 100 |
Posted: 29 Jan 2010 at 6:14pm |
I welded 12 ga. flat metal to my existing fender skin after grinding rusted out part,used angle for bottom edge & did braces/filling with bondo.
they came out decent looking
