What Weight are These?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: What Weight are These?
    Posted: 30 Jan 2013 at 2:27pm
Is this disk?  Any ideas what it weighs?
I need this info for tire info, ballast and PSI.  Thanks, Ted
Now how about this plow?  What series and weight?
Edited by Ted J - 30 Jan 2013 at 7:29pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 2:49pm
Don't believe the Disc had a Model No.
Simply referred to WD 8' Disc  (  if it is 8 ft. wide )
I would put 12 psi. in rear tires.
Gary
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 3:02pm
Disk is a 100 series
Plow is a 50 series
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 3:26pm
Any ideas on weight?
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 3:44pm
No idea on weight but Matt is correct about the series #'s.
Here's my #109 disc with ridge reducer extensions.
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 8:58pm
I am thinking of buying an 8.5 ft. Model WD-109 Snap Coupler disc like the one shown in this post, for use on food plots.   I would like to know what the approximate weight of it would be for hauling on a trailer.  Anyone know?  Thanks!
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 9:06pm
around 7 to 800 p' that would be tops'
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 9:09pm
I would guess 800 to 1000 lbs on the disc. I say that because we had a 12 foot ac disc here and the person who bought it unloaded it with a tractor that had 1200 lbs loader and that tractor wanted to tip over picking it up. Not much to go on but they are heavier then they look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 9:21pm
Thanks Bob and Dan for the quick reply.  With the hitch assembly off, I should be able to haul it crossways on the trailer we use for our Kawasaki Mule.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 11:28pm
there not that bad' i load the 8 footer i have with a small wd- loader i have on a wd it lifts it an moves it just fine'
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 6:16am
I used to haul a tandem set of drag discs on a 'REPURPOSED' 6 by 8 tent trailer, as it was a 'deck over' style. Used 4 2by8s as ramps and a hand winch on the D-14 to pull it up. If I'd used it more, I'd put the winch on the trailer,but their both gone now. Unloading was a lot easier...just grab the disc and let it roll off the back.
The trailer cost me all of 50 Canucks, and was dedicated to disc storage and haulage.Having the discs on it 24/7 made it easy to move around the yard here !
maybe an option ??
Jay
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 7:28am
They aren't very heavy. Maybe 500 for plow 900 for the disk? Once I saw posted on here a document that had all the model plow and their weights listed. Can't remember where it was. It was interesting to compare the weight differences between models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 2:41pm
If I'm not going too far, I just load up the WD-45 and disc hooked up.  You need the tractor almost to the front of the trailer and the disc gangs almost touch the rear trailer fenders.  It hangs over a little on each side.  I put flags on each outside edge and stay off the interstate.
When I bought it from a retiring farmers farm sale, I took the tongue off and loaded it sideways with a loader tractor onto the same trailer.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:02pm
Brian, that's a good looking disc!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:10pm
Anybody got any ideas where this is at??  Should be posted again and then saved1
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:15pm
in your book on these tools should have what the shipping weight is on each tool from AC''
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 8:26am
 Is not that disc a 200 series? If not what is the difference between them?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 8:37am
Dennis, my recollection is all of the 100 series discs were SC or pin-hitch mounted discs i.e. no axles/wheels; the tractor hydraulics carried the entire disc.  The 200 series discs were all pull type (either SC or regular drawbar) with a remote lift cylinder and axles/wheels.
Creston, I bought that disc at a retiring farmer's auction about 15 years ago.  The story goes that it had never sat outside overnight since he had it.  By the looks of it, I believe it.  It's only been outside a few weeks since then otherwise in a shed.  I paid $600 for it at the time.  The auction was just south of Altamont, IL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:47am
I looked but couldn't find it. Seems like I commented on the post if I remember right. There was a chart and list weights for like a 62, 63, 64 fully mounted, 62, 63, 64 semi mount. 72, 73, 74, and down the line. You could see how much the spring trips and such added.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:40am
Brian, What is that wooden "whiffle-tree" looking thing on the back used for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:46am
Brian, the previous owner made that "modification".  As best I can tell, the board is simply how he wanted to attach a support for the clevis that's mounted in the middle.  I believe the clevis was used as the hitch point for a pull-type drag harrow behind the disc.  I've never had a drag harrow behind this disc, but I guess you could.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 1:23pm
I finally found the chart.
I must be a fool. Charlie ALREADY posted that chart in a safe place. The knowledgebase section!
This page was generated in 0.057 seconds.
