Allis 2900 mk 2 649T
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Topic: Allis 2900 mk 2 649T
    Posted: 29 Jan 2013 at 9:54pm
I have an irrigation power unit that says on the tag 2900 mk 2 649 T. it has the in line simms pump on it. what else was this engine used in? a Gleaner L or M ?. I need info on parts for a rebuild and a service manual . has about 3000 hrs on it but the turbo went out and sent metal into engine also had a cracked exhaust manifold and let water in. former owner then pulled it out of service and then i got ahold of it. I plan on makeing a generator out of it.   Thanks for help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2013 at 10:20pm
1972/1973 model "L" Gleaner used a 2900 with a Simms in-line pump. They were never called a 649-T in those years. That designation came around 1977 and newer. Look around all over the block and see if you can't find a casting date like 72 or 78 etc.....this would give a better idea of the age of the unit. If it has a large oil cooler that wraps most of the way around the engine, it's closer to the 1972-73 era. If the oil cooler is above the injection pump area only, it's later like 1977 and up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 5:19am
I pulled a bunch of parts out of one of those engines, a coupla years back, that was in a buffalo springfield roller, IIRR.  It had thrown a rod, but I was able to salvage the manifold, and turbo, and head.  Threw my back out moving that monster head, by myself!
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 7:11pm
It has the long oil cooler on it .I,ll have to take a closer look for any numbers. Thanks for the info.
Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2013 at 7:46pm
i just went and took a peek for #,s. I thought the tag stated 649 t and 2900 MK II.  Serial # 2d-102473 . Model # 2900 MK II. ctalog # 4024290 and other # of 1-7451-86413. The oil cooler goes from water pump to back of motor and around just to the other side.
