226 260 cid setup
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Topic: 226 260 cid setup
    Posted: 17 Jan 2013 at 9:16pm
I have a cheap and easy parts setup I'd like to sell for someone looking to do a little upgradeing without breaking the bank or working to hard to do it.
Set of 4 IH 308 truck engine rods, 4.185 bore Keith Black KB194 .060 over pistons and rings.  2 pistons brand new, 2 slightly used (neighbor had bought 8 and had 6 of them in his 6 cyl tractor engine for a bit)
Works out to bore a set of 4 1/8 bore liners .060 over and offset grind the 4.5 stroke crankshaft to a 4.75 stroke.  You get a 4.185 bore X 4.75 stroke engine at 10.5 to 1 compression ratio.
The rods are 8.5625" long center to center,  use a 2.125" diameter crankpin and are wide enough to fit the Allis crankpin.  The wrist pins in the IH are .925" and the pistons are .927".  I have honed the wrist pin bushings to size and resized the bottom end of the rods so they are ready to go.
$300 for the rods, pistons, rings, wrist pins and new spriol locks shipped to you.
I do have nice used 4 1/8 liners available at additional cost, but I'd prefer to keep them.  Approxamate cost to bore and hone the liners is $100-$125, offset grind the 4 cyl crank $250.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2013 at 6:25am
what kind of power output would this give?
Charlie
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2013 at 12:14am
do you still have these parts?
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2013 at 12:47pm
Yes, I still have them, allong with bored sleves with new o-rings.  Also a 5.75 stroke crank and 8" billet rods for another combo.
715-790-1869
This page was generated in 0.170 seconds.
