190 Bareback ?
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: 190 Bareback ?
    Posted: 10 Jan 2013 at 2:06pm
 My friend that pulls a 190xt allis wants to find the parts to make his a Bareback. No pto,3 point, it is a modified class with aluminum frame rails. Wish I had a picture to post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2013 at 2:24pm
Its easy to do, pull off the rear 3 pt housing, cap the 3 pt hyd lines, pull the pto shaft outa the back, put a steel or aluminum plate on the back where the housing was and you got it, could foam the rear end so you dont need so much oil, but if you dont need to worry bout the weight loss dont worry bout the foaming
Edited by DougG - 10 Jan 2013 at 2:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2013 at 6:10pm
You'll need to stick a short dummy shaft in where the PTO was to keep the hydraulic and trans oil where they belong.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2013 at 6:37pm
I would like to do the same to mine this winter if I can get all my home improvements done. It seems simple enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2013 at 5:45am
It's very simple to do,
Edited by DougG - 11 Jan 2013 at 5:46am
