tire chain size chart
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: tire chain size chart
    Posted: 06 Jan 2010 at 6:18pm
I got a  set of tire chains given to me but I dont know what they fit. they measure 24" by 11' any help is appriciated.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Justin Widlund (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2010 at 7:17pm
I also have a few sets and don't know what size they fit.  Someone (tire co., chain supplier. etc.) has surely made some sort of basic chart, but my prior searches have not turned up much.
Any ideas?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2010 at 7:31pm
I've been looking for the same thing.  Maybe if everyone on the forum reported their chain dimensions and the tires they use them on we could make such a chart?
phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 11:06am
 ttire diameter x 3.14=approx. length(ex. 55''x3.14=172.70''
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 11:28am
When calculating tire diameter X 3.14, be sure to measure the diameter where the side chain links will actually ride on the tire.  Rim diameter isn`t helpful when calculating chain length.  Tire width is also important to know.  The wider the tire, the longer the cross links need to be.  Had to make up chains for the Caterpillar 140G  used for snow plowing at the Village where I worked.  Hope I didn`t confuse anyone.  It`s much easier to show someone than to explain it.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 12:38pm
3.14 x diameter will give the distance around the tire, but the chain side links and distance that the cross links cover are what's important and this is what people usually measure when the chain set is laid on a flat surface.  I've looked for a chart too, and haven't had any luck.
One site that shows what chains will fit what tires sizes is;
But, it doesn't state what un-installed length is.
There's a topic (video) on there on how to determine the size of chain needed if the size you have is not on the charts, however, it only goes as far as having you measure the tire and submit the dimensions to them...doesn't tell you what actual length is needed.
Just guessing with what they are asking, that the length of the chain set is a factor of those dimensions and through some algorithm, they determine the overall length.
They also have a video showing how to install the chains, with steps showing how to shorten the sides....  so, the length they'll provide is more than likely purposely too long as they'd not want to ship you chains that are too short.
drdva View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote drdva Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2016 at 9:15am
I have a set of tire chains that are 73" long and 12" wide. Anyone know what size tire they will fit?
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 8:07am
I found this.
How many times have you found a set of tire chains with no size information and wondered if they would fit your intended usage? To see if tire chains will fit: measure tire tread width (W) and tire height (H). Measure, don’t use tire size! Measure tire chain length (L) and inside span (S) of the chains you are checking. Subtract W from S and then subtract that number from (H) which will give you the diameter of the tire chain circle. Multiply that by 3.14 and you get the tire chain length (L). Remember you can add or overlap a few links on the chain length to make minor adjustments and a wider span requires a shorter chain length. Also. A few pounds more or less of air pressure will allow more latitude in the fit. I hope this is useful to someone.
   Al
Glenn (NJ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn (NJ) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 8:43am
Here is a link to a tire chain mfg./supplier:
http://www.lacledechain.com/tc_catalog/FLASH/index.html
Go to the back of the catalog to the specifications section, go to the table for the type chain you have (truck, tractor - ladder, duo-grip, double ring). Match the length, width, link diameters and note the assembly #.   Go to the front of the catalog fit charts and you can match the assembly to tire sizes that that assembly will fit.
npoulson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote npoulson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 9:28am
To drdva
I an thinking maybe 7 x 26.
Do you still have the chains I may be able to adapt them for my self if you want to sell them.
Edited by npoulson - 12 Dec 2016 at 9:31am
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 11:23am
Alleyooper has the right Information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2016 at 6:07pm
I always just take one and mount it on the tractor I want it to fit.  If it don't fit, I know its either bigger or smaller than what I want.  Murphy's law subparagraph 13 (b) section 2 states, that if its free, it don't fit anything you have...Wink
