transmission lock up
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Topic: transmission lock up
    Posted: 15 Dec 2012 at 12:10pm
I was going for just one more bucketload with my HD6G when my transmission locked in high speed reverse. It is solidly in gear not caught partly in 2 gears. The transmission locking plunger is moving correctly. I removed the locking plunger sleeve and boot and moved the locking plunger several inches but I could not remove it.
I wiggled the shift lever but it didn't come out of gear. It is not in a good location for me working on it. Sugestions please.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2012 at 1:28pm
You could removed the 2 bolts from housing shift lever and pull out the lever gear shift  and check inside with a light  if the end shafts notches are in line and if not ,use a long screw driver inline the 3 notches  and reintaled your shifter and try to shift and the master cluch must be in neutral fonction
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2012 at 8:55pm
side bolts into shifting tower . remove full lever and the shift fork ball .
using a long screwdriver or a jack handle tire iron = move all 3 forks into neutral position .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 12:59pm
I'm shifting again. Thank you to gemdozer and Coke-in MN
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 1:03pm
always nice when someone post that problem corrected and a thanks !
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 2:07pm
I got my dad 6g hung in geer a few times and we would pull the shifter and pour a little oil in it and reline the forks usualy it got hung in high forword geer.
