hd11 clearing scrub and deep ripping
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Topic: hd11 clearing scrub and deep ripping
    Posted: 13 Dec 2012 at 9:49pm
Hi all , thought i woild share a couple of pics of my hd 11
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2012 at 9:50pm
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2012 at 4:19am
Nice pics and dzr too steve, thanks for posting !
Don,t be shy about putting up more ! !
cheers from kiwiland !  merv
tits tyres and tracks
they all cost you money
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2012 at 3:56pm
Sweet!!!!!!! Looks like your well protected. Could sure use  one of them on some of our ground! Nice outfit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2012 at 3:59pm
Nice root rake, I have always admired your machine but that is awesome!  I could sure use that here!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2012 at 3:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2012 at 12:56pm
Looks, Runs and Sounds Sweet !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 9:35am
Steve, what's the weight on yours?  I can get a 11B here for $18000 US but is missing a few guards on the rail trucks.  What issues are most prevalent on these?
Is listed in Contractors Hotline under crawler tractors as a '74 with recent trans work.   Man in Salem MO, Mike Smith.  He also has a 14C for $24xxx with newer SALT rails.  What engine are these?  What pitch rails, parts any harder than my 7G to get?
Dave
Edited by DMiller - 16 Dec 2012 at 9:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 12:38pm
THe 11B was made in SPringfield Illinois, the 14C was built in Italy.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 9:14pm
Nice tractor Steve!  The Series B was the cream of the crop in '71.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 9:20pm
DMiller-
Some of the issues with these 11's have been discussed on earlier forum posts.  Loose accessory drive bearings and vibration dampers that have fallen apart are common on these machines.  Breaking #1 injection line is first sign of bad damper, breaking crankshaft is bigger sign!  Another thing- if the machine won't push until it's hot, could be a sign of worn clutches in transmission.  Any used machine is a gamble, but these tractors were made as good as any, and for the most part, pretty good to work on.  Of course, the power shift models are much "busier" under the floor plates than the standard shift...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 9:24pm
Here's ours in a colder environment...
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2012 at 6:13am
thanks for the coments, That looks like a late model 11 with the cab ''NICE''
does it have a muffler under the hood?
thanks steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2012 at 11:08pm
No muffler- she's a '74, has the old P Bosch pump on 'er.  We used to have a later one, a '76, which had the muffler originally, and had the MK2 engine.  Kind of have seller's remorse, but oh, well...
This one I picked up sight unseen at auction this summer, haven't used it much yet.  I bought it real cheap because it had a bad oil leak on the converter, the old man thought he had a serious torque converter problem, and would not let them run it at the auction.  He just about had a cow when I told him after the auction that there was supposed to be oil in the converter housing, and offered to buy it back.  Turns out the starter was just loose, there is nothing wrong with the converter.  Sometimes you win, sometimes you lose.
I called the old man up before the auction and asked him what he thought the machine was worth- "well", he said, "I won't let it go for less than $5000", so that is what I bid, $5100.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 6:37am
Awesome catch for the money.  It has a straight blade or a semi U on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 8:49am
Is a angle blade
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 12:31pm
Thanks Merv, only seen two tractors ever set up with a angle unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 2:55pm
Was probably a 60/40 mix of bull vs angle blades on the 3 tractor brands [D6 HD11 TD15] in that size sold here. HD6/D4 size was 99% all angleblades. Each has advantages/disadvantages. Actually have both for my D6D. But neither will ever get to push that 'funny' white stuff Big smile
Merry Christmas to all on here. MervBeer
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 3:05pm
Merry Christmas to you Merv and all my other cohorts here too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2012 at 11:32pm
Tractor came with bull blade, but we put this angle dozer on it for snow.  The angle dozer was very popular in western Canada, it's the only way to go for plowing snow.
Yes, and Merry Christmas right back at you all!
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 2:29am
HD 6 Merv
Careful - looks like global cooling is edging back into fashion, so you might get a chance!
Merry Xmas to you all
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 1:13pm
Hi Ian; yeah this global warming is a myth down here. But cooling yes weather patterns do seem cooler here. and maybe wetter too. Cooler, we can always put on more clothes; hot you can only take so much off. But is good for the girls who like there bikinis tho; and good for us who like the girls in there bikinis Wink. Cheers mate Beer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2012 at 2:43pm
HD6 Merv,
I once heard this description that
"a bikini is like a barbed wire fence - protects the property without obstructing the view"
This page was generated in 0.508 seconds.
