H3 crawler turning clutches question MORE PICS
warddc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Topic: H3 crawler turning clutches question MORE PICS
    Posted: 09 Dec 2012 at 10:49am
Which way should the spline shaft slide? I can move the shaft back and forth a 1/4 inch or so. If I can get the retaining clip off, does the shaft slide into the clutch pack or toward the tranny housing? It seems like it is bottoming out in the direction of the tranny housing already. Not sure which way I should be moving the shaft.
Edited by warddc - 19 Dec 2012 at 7:22pm
1962 H-3 Dozer
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 1:00pm
I'm sure it slides to the center. May have to take the rear plate off to see what's going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 3:44pm
I bought a fiber optic camera today so I could look at the c-clip I am supposed to be taking off. I think I can see it. It looks like it wraps around the flange of the spline hub that is in the clutch pack. Going to have to make a tool to pop that clip off. Can't see it without the fiber optic camera. Have no idea how to get off a spring clip that I can't reach or see.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 5:17pm
i have hd4 and had to bend a long thin blade flat screw driver in a 90 degree angel about one inch up on shaft and flatten end with hammer so it can slide under the c clamp. once you feel clip apply pressure and lift out at same time. you can feel with a finger and know when it frees up. i must slide toward the bevel gear rear end to lift clutchs out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 5:56pm
Thanks for the help. I will try bending up a screwdriver and flattening it to make it thinner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 7:07pm
let us know how it goes
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 10:18am
Will do.
Does anyone know where i can get a brake drum for the turning clutch pack.  the left one is serviceable but the right one is worn through.  I see minnpar.com says they have them new for $550.  ouch!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2012 at 12:00pm
I have a used brake drum #(am 4864)
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2012 at 3:15pm
Excellent. What do you mean am 4864? Can you email pics and how much you want for it?
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2012 at 3:38pm
THE AM4864 is the drum part number and you can see the part number on when the drum is removed from the hub and plate and have no picture and want $60.00 plus shipping
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2012 at 5:24pm
What condition is the drum in? How worn is the braking surface?
1962 H-3 Dozer
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2012 at 6:58pm
I hate those clips, seem to always be a fight, my paw is pretty big and just doesnt fit in there too well to pop it off,
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2012 at 10:59am
My h3 brake drum outside and inside is in good condition
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2012 at 12:38pm
IM sent.
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2012 at 5:07pm
Well, I got both turning clutches off. Was pretty easy with the fiber optic camera so we could see the clip and get under it to pry it off. We also made a tool from a piece of 1/4" steel rod. Bent it about an inch from the end to a 90. Then ground the tip really thin like a knife edge.
The shafts slide into the center of the tractor. One shaft actually pushes against the other when they are both slid in. When one shaft is all the way into the throw out bearing the other shaft moves out 3-4 inches.
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 3:08pm
Here are some photos now that I have the clutches out. I have ordered parts and am waiting for them to come in. While I am waiting I am cleaning up the clutch wells.
before.
after.
here she is in the garage getting tore apart.
Edited by warddc - 16 Dec 2012 at 3:33pm
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 3:42pm
looks real good after cleaned up. where did all the oil in cases come from ? if it is out of the bevel gear end ( rear end ) section then the seal must be down and since the clutches are dry type, if seals are leaking, you will be back at the same job a little later. i just rebuilt one side and had to pull the cap out to replace the seal. not a big job at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 4:22pm
I am not sure where the oil is coming from. Could be either the transmissions seals or the final drive seals. It took fifty years to get like that and both plugs were still in the bottom of the clutch wells. The new clutches will outlive me.
Edited by warddc - 16 Dec 2012 at 4:22pm
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 4:36pm
hope you are right. the plugs are normally open to allow drainage, unless you work in dozer in really wet areas where water could get into the clutches. my plugs were out and the oil out of bevel section ruined the fiber ones. clutches slipped and brake band wold not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 4:48pm
I can take a look at replacing the bevel section seals while I have it open. I don't have the equipment to change the seals on the final drive. You have to remove the track drive sprocket. Can you get at the bevel gear seals from the turning clutch well? The parts book shows an o-ring to seal around the flange and then an inner seal around the shaft near the bearing.
Edited by warddc - 16 Dec 2012 at 4:50pm
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 7:48pm
I JUST PULLED MINE AND REPLACED THE SEAL. I TOOK A SCREW DRIVER AND KNOCKED THE SEAL BACK TOWARD THE BEVEL GEAR. TOOK 2 BOLTS AROUND FIVE INCHES LONG AND WITH A 3/4 INCH CARRIAGE TYPE HEAD. GROUND ONE SIDE OF BOLTS FLAT TO BOLT SIZE. GROUND OPPOSITE SIDE ENOUGH TO GET IT TO FIT BEHIND THE FLANGE STOP FOR THE SEAL. PUT A FLAT BAR WITH TWO SLIDING SLOTTED HOLES. PUT TAPS ON AND TOOK SLATE BAR BEHIND BAR, GAVE A LITTLE PUSH AND IT POPPED OUT. SLID CAP OFF THE AXLE AND PUT SEAL IN. LINES BACK UP PUT TWO BOLTS IN STARTED TO EVENLY TIGHTEN TILL I GOT BACK TO BEARING. LIFTED SLIGHTLY UPWARD ON AXLE AND EASED CAP BACK INTO PLACE. THEN PUT THE OTHER TWO BOLTS IN, TIGHTENED GOOD. PUT CONE BACK ON OVER AXLE. TOTAL TIME FOR JOB 1 HOUR.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 8:26pm
I was thinking I could just remove the four bolts that hold in the bearing carrier (behind the throw out bearing yoke) and pull it out. The seal for the cross axle is in this bearing carrier. I am not clear on how you replaced the seal from your instructions. Did you replace it from accessing through the pto housing?
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2012 at 8:44pm
ONCE YOU PULL THE CARRIER YOU WILL NEED TO DRIVE THE BEARING RACE OFF AND THEN THE OLD SEAL. REPLACE WITH NEW SEAL AND THEN PUT BEARING RACE BACK IN . REPLACE CARRIER, PUT 4 BOLTS BACK AND JOB DONE. YOU WILL NOT NEED TO REMOVE BACK PLATE WHERE PTO IS. ALL CAN BE DONE FROM INSIDE STEERING CLUTCH HOUSING.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2012 at 5:50am
by the way, what kind of shape were the clutches in when you tore the unit down? were the oil soaked on outside and the fiber plates ? did both sides appear the same ? when i checked mine and discovered the problem, i took the throw out bearing carrier off and took mirror with light to look at seal and found rubber damaged and protruding toward the steering clutch. that is why i had to pull the cap and change mine. it is not a real big job. my e-mail is randal.thornsbury@aol.com send pm and i will give you my home phone # in case you need to call me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 7:34am
Thanks for all the help.  On the left side everything was oily and the right side was fairly dry.  I am going to replace both seals since i have everything open.  I am waiting on seals from minnpar now.
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 2:04pm
have you pulled the carriers yet ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 2:15pm
nope.  probably tonight.  I think that I have to drain the oil in the tranny to get it below the level of the carriers.
1962 H-3 Dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 6:24pm
yes drain the oil. probably a smart thing to replace both sides while down this far. i don't guess having both carriers out at same time will hurt about alignment since axles are left in splines on bevel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 6:28pm
by the way did you go back with fiber clutches or the bi-metalic ? i went with bi-metalic and bought them from webmasters@tractorparts.com . paid 172.35 for 4 bi-metalic clutches and 3 new steel plates. all aftermarket new items. new bands are 145.00 each they are in idaho. bought bearings and seals from napa store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote warddc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2012 at 7:45pm
I went with bimetallic as well. New bands, bearings and seals.
1962 H-3 Dozer
This page was generated in 0.602 seconds.
