how do i tighten tracks
rkbrkb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rkbrkb Quote  Post ReplyReply Direct Link To This Post Topic: how do i tighten tracks
    Posted: 07 Dec 2012 at 6:11pm
I HAVE A  HD5G19311 TRACK LOADER WITH A BACK HOE ON THE REAR.  I HAVE A TRACK THAT IS LOOSE AND WOULD LIKE SOME ADVISE ON HOW TIGHTEN THE TRACK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2012 at 7:49pm
The track adjuster is a threaded piece that sets parallel to the truck frame. On front end is a clamp with 2 bolts that go into front idler bracket, loosen these 2 bolts to allow movement of threaded portion of adjuster , lube threads with penatrant and then with large wrench turn adjuster out to tighten chain.
 If it has been a long time since it has been adjusted it may be frozen and heat will need to be applied. If this still does not work as a temporary fix you can shim the idler at end of the yoke or at cop end that sets on spring . Next is to split the track remove the full adjusting yoke and repair or loosen off the machine - then replace .
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2012 at 4:50pm
Also remember the tracks on a dozer are not supposed to be totaly tight there should be some droop in the top of the track.
