HD5G starter upgrade
highrideford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Topic: HD5G starter upgrade
    Posted: 30 Nov 2012 at 8:34am
  Has anyone converted their starters over to a solonoid operated starter on their dozer. I was wondering if their was enough room with the blower being right above it. I can get a new Delco MT39 or MT40 for fairly cheap and just wanted to know if they would fit before i buy one. I dont really care to rebuild the old one if i could get a new one that fits
Thanks
 Jeremy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 8:44am
The Delco starters have a rotatable nose, if it does interfere you may be able to re-orient the nose for clearance, just remember to align the cupped areas for the bolts to fit up correctly, no 1/2 hole adjustments.  They do also make alternate nose housings on th motor itself with the bolt holes oriented 1/2 hole off to the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2012 at 11:44am
They work great, I have put them on every machine i rebuilt, the old style or original is hard or impossible to find parts for . I have 2 or 3 of them somewhere.
 As I also converted over to alternator the idea of a key switch in system worked great . Mounting is no problem as it is a direct fit or replacement .
They are easy to find and at a right price in many areas. Seems they are standard across most truck engines and the supply is good on rebuilt or used takeouts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote highrideford Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2012 at 10:17am
Thanks For the replys. I bought a delco 39mt will be installing it this weekend hopefully.
This page was generated in 0.104 seconds.
