Tires...
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Tires...
    Posted: 28 Nov 2012 at 9:15am
Ok I run 13.6x28's on my WC but keep hearing the same thing. Switch to 38's....with piss poor gearing ratios and stock engine, why? What's so much better about a taller tire? This question has plagued me awhile. I run farm stock and usually 3mph. I understand wider, just not taller.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 2:37pm
I'll let smarter people than me answer this one, but, I will say that I have a set of 18/19 - 26 combine tires on one of my WD's and set it besides the one w/ 12-28's and they are the same height which should, in my mind mean the same footprint
I am still confident of this;
Wait for the Lord;
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 6:25pm
i used to think like you guys,until i saw the guys with 38's beating me with 16.9x26 tires.put the combine tires back on the combines.look at the bottom of 38 tires then look at the bottom of 28 tires,38 tires will have one more bar almost touching the ground,when you start to pull hard,the third bar will be pulling.I am glad i switched when i did.good luck.PS-the guys beating you already switched,probably.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 7:39pm
Mike nailed it! I did the same comparing between 34's and 38's and there is quite a difference even there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 8:54pm
16.9's, not 18/19!
Wait for the Lord;
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 9:44pm
question to add on?  what rims an you use fo 38's or do you have to make adaptors etc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 10:45pm
I run pressed steel (9 bolt) wheels with adapters made for use with axle mount duals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2012 at 9:42pm
i used band-type duals with f&h flat-spoked hubs,it was a lot of work,but well worth it.a lighter option would be to use centers from a f-20 farmall.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2012 at 10:47am
If you need adaptors for your wc 6-9 bolt my son makes them $170.00 for a pair shipped to the lower 48 states 517-285-6156
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2012 at 12:33pm
most pulls go by the natpa sqare inches tire chart that use to be on the firestone ag site . Its pretty straight foward run the largest square inches of foot print they will let you
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2012 at 10:03pm
our club allows 210sq.in. limit,i believe my 15.5's are just below that.
colroy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 8:26pm
you can use f 20 farmalls wheels they will bolt right up
