my wc that i pull if this works
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Topic: my wc that i pull if this works
    Posted: 23 Nov 2012 at 8:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2012 at 8:54am
How bout that ive finally been able to post a photo. Guess the new phone is okay after all lol
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2012 at 9:19am
nice. I like the holes in the front and rear wheels. a little different than most tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2012 at 2:10pm
Thanks the holes were to help get down to 3000lb think i lost a whole 10lbs lol but since i just made it by about the same amount i guess it was worth it lol
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2012 at 7:15am
 Eric,
  That looks to be one BAD A$$ set up. There are a few around here with WC crossed with WD 45 and D17. They always are a force to be reconed with espically in the light classes. My winter project is to find some 38" rears, and some smaller fronts. A 38" rim with an 8 bolt pattern must be rare. I want to run 15.5 x 38, I am running 16.9 x 26 now, cant apply horsepower in lighter classes.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2012 at 8:36am
Yea i think 8 bolt setups are hard to find.
I made 6 to 9 bolt adapters out of have inch steel
i imagine it could be done for your setup two. I dont know
what weights you run but 13.6 38s work good for me from 3000
To 4500 typically occasionally ill run 5500 farm stock
