HD6E Correct transmission & Final Drive Oil
drtdmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Topic: HD6E Correct transmission & Final Drive Oil
    Posted: 20 Nov 2012 at 4:33pm
Can anybody tell me the correct oil to use in the transmission & Final Drives of a 1959 HD6E. I have heard various oils to use including 80-90wt. gear oil, 30wt. motor oil, 85-140 wt. gear oil, what is recomended.???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2012 at 4:45pm
Might be time to invest in a service manual.  My 7G at least had a lubricant chart on the steering filter cover so I knew where to start.   My finals take 80/90, the same should be in yours, my trans/bevel gear takes Type A ATF(using Dexron), I believe yours will use 50wt motor oil.
Edited by DMiller - 20 Nov 2012 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2012 at 5:09pm
Thanks DMiller, i had forgotten about the 50wt. in the trans. your absolutely correct!
