ALLIS V8 & V12 ENGINES
big al View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS V8 & V12 ENGINES
    Posted: 10 Nov 2012 at 10:21pm
ON A LEED ABOUT ALLIS V8 & V12 GEN PLANTS IN A HOSPITAL BASEMENT NEAR THE OLD HARVEY ENG. PLANT.THE V8'S WERE CALLED 4100 AND 4500 THE LATER BEING INTERCOOLED 1358 CI(6X6 B&S) 600HP TWIN TURBOED ,MAYBEE LESS THAN 20 MADE.V12 6100,6500 2036CI SAME SPECS AS ABOVE 900HP LESS THAN 50 MADE.WILL LET U GUYS KNOW IF I TRACK THEM DOWN!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:19am
Id luv to see one! !! That is a very good find!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:34pm
Here are some pictures of a V-12 that I've been negotiating for four years.  Thats me in front of the rad. Thought I had a deal once be seller changed his mind. Where did you get the production numbers?
I have a brochure on the V-12 (7208) and a preliminary spec on the V-8 and V-12.
Talked a a guy who saw the V-8 being tested in the HD-41 but they would grenade after about 1000 hrs. Sam T said there was a proto type V-8 in Georgia but I didn't know the V-8 went into production. Either one would be a great score!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:46pm
Had to delete some from the file to post more pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:48pm
I hope you can get it. Looks like a great find. I could put it to good use. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 8:05pm
i do have some service papers from harvey,they give some serial #'s on the v8's,i am guessing on the total of 20,i have up to #13.on the v12's the parts book gives serial #'s on different orders,i think i have seen #43.maybe somebody has more info on these engines?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 6:58am
If you see them we want pictures.......and lots of em........Big smile
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2012 at 2:03am
Any new info ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2012 at 8:17am
It's not on the AC engine of the V 12 but on the design itself , but a good read of the basic V 12 design and use . Seems the engine type has been around for a long time in both gas and diesel use in planes, ships, tanks , trucks and automotive use as a luxury engine.
goatdope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goatdope Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 3:14pm
I had the pleasure to overhaul a few of these beauties at the AC plant back in 76-77. Some 550kw gen sets had failed under warentee while having the guts run out of them by the staggaring Penn Central railroad. I personally can testify to at least two of the engines shortcommings. As for power, there was'nt a dyno in the whole harvey plant that could hold a ungovernd V12 . As I recall the break in & power curve was done with the gen set tied into 2 load banks.
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 4:10pm
The picture doesn't give the impression of the great size of this engine until you compare it to the alternator! And what about those sewer pipe-size inlet ducts.. ..What kind of hospital could need a generator of this size, unless they're trying to recreate the Frankenstein experiments?
This page was generated in 0.258 seconds.
