HD6E Filter Numbers
drtdmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Topic: HD6E Filter Numbers
    Posted: 03 Nov 2012 at 12:37pm
Sorry About the first post hit the enter button instead of tab button.
Anyway i am looking to see if anyone could look in there crawler parts manual for a HD6E Ser.#10137. Looking for oil,fuel, and air filter numbers for the tractor engine.
Any help?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 12:51pm
Your 6E, is it Allis four stroke 344 engine powered?
I could only find filters for my 7G thru Baldwin:
They still list the 6E with the 344 and the 6000 series engines.
Fuel for either: Pri PF916C, Sec PF906
Full Flow Lube: PT46 OBS for the 344, PT115 for the 6000
Bypass Lube 344: C704 L
Hydr for the 6000: may also fit the reservoir on the 344: PT82 HD
Trans on the 6000: PT 265
Air filters: single: PA 1684, two part round: PA1902FN (O) PA 1912(I) Square tubular late model: PA1775
Good luck crossing any of these to other companies, I wound up sticking with Baldwin online as they were the sole provider now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 12:58pm
Yes i do beleive it is the 344 buda design motor for that year tractor (1959). Inline Four
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:05pm
Thanks DMiller , for the Baldwin website!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 2:39pm
Double check the cross reference on their site to look at the filter dimensions, some are not correct by model, others were with some were introduced on a early model but continued on the later.  So far the filters I have gotten are direct replacements.
Is yours a 6E plain or EP?
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 2:44pm
Whats the difference?? I dont know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 3:22pm
EP has power assisted hydraulic steer, similar to my 7G, yours being a early it is probably not.
Edited by DMiller - 03 Nov 2012 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtdmn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 3:30pm
no i don't believe that it is power assist
