Power Steering for 'D' grader?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: Power Steering for 'D' grader?
    Posted: 01 Nov 2012 at 1:51pm
We just picked up a 'BEHLEN' power steering unit from a D grader for another D grader.
I have seen one other D grader with Behlen power steering but the parts book shows a different unit. Was Behlen power steering a factory installed unit or was it aftermarket?
I'd appreciate any pictures of power steering units on a D grader. These have all been 1966-7 square frame D Special graders that also have all the other options.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 6:29am
well i know nothing of the D grader but i thought i read in Norms book that only the larger graders had factory power steering at that time.  I may be thinking of the mid 50's not the mid 60's.  however, if it shows up in the parts book maby it was a factory option.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:12am
I have a parts book for s/n's 5425 and up (round frame) and they do not show any power steering in their options. Power steering may have been introduced when they came out with the square frame. Literature that I have says that they went to hydrostatic steering for the M65's. I have seen two of the older machines that have adapted some type of power steering. One machine went fully hydrostatic and the other machine took a steering box with power steering from a pickup truck and adapted it to his grader. The first one used the grader's hydraulic system and the second one added a separate hydraulic pump. I have added power assist from a sp combine to mine and used a separate power steering pump. I can now steer mine with one finger. I should try and post some pictures.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 5:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:31pm
Just checked my Aug 1967 'D' grader brochure and on the cover and inside on the options page is a Behlen power steering unit. Mystery solved. Behlen was an OEM supplier to Allis and these were a factory installed option.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:38pm
Behlens were built in Columbus Nebraska. Business is still going but now they make steel panels and buildings. Behlen was quite the inventor as he also made Behlen ear corn cribs. We have a Behlen power steering on our D grader as well as on an international H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:41pm
Calvin i will try to get you some pictures of our Behlen set up
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2012 at 11:58am
The Char-Lyn power steering torque generator provides a very simple retrofit method; remove a small length (approx 8") of steering wheel shaft, install the torque generator and run supply and return hydraulic hoses to pump. No cylinders and no hoses to cylinders.   Works great on our D-14.  At least one of the suppliers that support this site offer Char-Lyn products. Herb(GA)
