More work on the old girl
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: More work on the old girl
    Posted: 28 Oct 2012 at 5:51pm
Been getting used to the manuevering I can now do but as I get into projects that could drop things I decided to rehang the cab guard, went to whittling on it to repair the crappy welds and broken supports but had to stop on the old one, too much damage so it becomes scrap iron.  This is the beginnings to the replacement I worked on today.
I had the square steel from a previous project, .250 wall as opposed to the gauge metal in the old one, should take a 48x54" section of 1/8th inch to cover then find some expanded metal or woven screen for the limb shields.  Will be a few days cutting and drilling the 'ears' for the bolts to go at the ends, putting pipe pivots for bolt mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 5:55pm
I also got started scrubbing the old round pipe stanchions off the frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 6:29pm
Well I forgot the camera this time, but I do have the frame squared and fit tested, next is to finish the leg ears and expanded metal shields then paint and install.  About two days serious work ahead but well worth it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2012 at 6:01pm
Here is the intermediate product, soon to e installed as to why the fourth foot is not in place.   I do not trust as to being too square and plumb so will tack it together as I final fit the guard.
Edited by DMiller - 04 Nov 2012 at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 4:33pm
End result, still will get expanded metal rear panels and possibly a side panel to the right but fits up nice.
Used the old girl for an hour, started smelling trans fluid, has a leak and the steering quit before I could get to the barn.  I am hoping the pump did not fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 4:39pm
More views
David Gantt N.C. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gantt N.C. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 7:20pm
Fine job , thanks for showing
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2012 at 9:47pm
very nice work !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2012 at 10:19am
Ended up a little depressed this morning, pump for steering is not operating, tractor is out in the field and weather is set to turn crappy, story of my life!  Put a pressure gauge on at the discharge lines at the filters, zero pressure, no fluid movement, fluid was still just below full so leak was not the issue.
Sat down and emailed DES Beloit, Eric has contacted Minnpar as to any kind of warranty, IF there is any, surprisingly the alternate 6850861 CNH kit is back in stock so I went ahead and ordered it.  I suspect the little over an hour I had out of the old new one was $1900 dollars worth of machine time but will see how they look at it.
Won't be able to get back to the machine until Tuesday or Wednesday next week, maybe later, hope the pump gets here before then, another 6 hours of pump r&r work to do next week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 4:15pm
Surprisingly, the new pump has arrived, appearance is similar to the OE Barnes unit but a little heavier.  Not sure what to think on the mounting, out of the six bolt holes only four are thru and thru, the upper inside and the lower inside are not usable as to bolting up, anyone ever use one of these?
Edited by DMiller - 13 Nov 2012 at 4:16pm
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 10:12pm
You're an awesome fabricator!!!
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 12:39am
What was the drive coupling like dave ?
Is it possible it broke ? Hopefully pump is ok.
wishing you luck mate;  not that ive got much in my life lately !
Cheers Merv
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 5:33am
Morning Merv,  I find out this morning if the coupling sheared or if anything worse occured.  DES has said they would warranty the pump should it have locked up or internally damaged in the hour of run time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 3:39pm
Merv, it was cracked, pump was locked tight as Dick's hatband.  Still had fluid at inlet and outlet ports so I called DES, they are setting up a warranty return to Minnpar for me so should be covered.  Luckily I still had the OE drive coupler from the first swap, went together OK, still apprehensive on the loss of two mounting bolts but no leaks.
