anybody pull with a "C"?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: anybody pull with a "C"?
    Posted: 28 Oct 2012 at 11:16am
How do they compete at stock level? What competition are they against. Best weight classes for C? Does anybody pull this class in West Ohio area? My daughter and I would like to pull our C, we have it restored and it still has the original 10-24 tires that are of course very hard and road worn.Thanks for any advise, JM
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 11:42am
What town are you close to?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 1:34pm
I live near fletcher, a couple miles from Barney Taylor.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 6:53pm
Look up WesVA as he pulls a C and CA
2500 to 3000 lb classes.
Does good vs IH A/B's
3000 lb you will be against CA's and IH C's which are tough.
put front weights on it as it will dance pretty quick
Charlie
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 7:15pm
ck with ken in carthage texas,he pulls a ca and quite well with it.....
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 7:21pm
10-4 on the front weights.  My '43 has the heavy cast rear hubs that were intended for steel wheels, and this makes it too heavy to add front weight in the 2500 lb class. This makes the front end come up at about 65 feet at any reasonable drawbar height.  Note to self:  Find light hubs so I can compete with Charlie175 and WesVA...
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2012 at 7:46pm
a guy here pulls one.
I think he pulls in the 2500 and 3000 class.
He's pulling against B's, deere M's, and an oliver in the mix.
not sure if his is exactly "stock", since the governor winds things up a bit.
Good luck.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 1:21pm
We pull a couple of Cs and a B and won trophies with all three tractors last Saturday! If you are pulling a sled that's friendly to smaller tractors you won't find a better puller at 2500-3000 pounds. Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 1:58pm
We need to dominate the local pulls with our little A-C's! Smile
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2012 at 6:55pm
nice balance on this C
[TUBE]S-wM7QizW-k[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 6:59pm
Charlie??  This is one of our pulls.
that's the C I was talking about.
Did you pull that day at Bowles' Farms?
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2012 at 7:01pm
also Charlie...
do you pull at the Heritage Festival in Luray every year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 5:44am
No I haven't been up that way to pull, really haven't ventured an hour radius from home yet. Hard to find info about pulls in the area.
Yes I do about every pull locally that I can, you been down to Luray?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 7:59am
been there once while camping.
Its about a 3 hour trip for us, but want to visit that show again sometime.
