Model forty-five motor grader
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: Model forty-five motor grader
    Posted: 16 Oct 2012 at 9:26am
I am planning on going to get my forty-five road grader this weekend, and I think I want to change the oil and filter in it before I try to start it up. Since it is 150 miles away, I can't look at it to see what it has for oil filters, so could someone help me out there?  It has the 516 buda/ AC engine in it. Does it take one filter/2 filters? Are they spin on or canister, and what is the filter (or filters) numbers. And how much oil should it take, and would cenex 15-40 super lube be an acceptable oil?  Thanks, Darrel
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 4:03pm
Darrel,
From my service manual
3.5 gal SAE 30
Single element
Allis Filter #4371021 - seems to be readily available here
I'll add some bearing translations some other time from our experience.
Have fun!
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 6:17pm
Thanks Ian. I'll keep you informed on how it goes. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 8:26pm
forgot to ask; is the electrical system 12 volt or 24? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2012 at 3:31am
Darrel,
24 volt.  If you've still got the generator on, it looks like (from the wiring diagram I have) that it is positive earth.   Might pay to check.
I've gone to a Bosch alternator and am using negative earth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2012 at 9:08pm
I got my road grader home yesterday, but unfortunately I was unable to get it running. The engine seems to be stuck. Could be something serious, or minor. The guy that I bought it from had dumped diesel fuel down the exhaust  to "keep it from seizing up", and we think maybe there is a cylinder or two full of diesel locking it up. Will keep working on it. Darrel
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2012 at 10:12am
I am't sure but you need to removed the injector and refill with diesel not in exhaust
This page was generated in 0.191 seconds.
