Model G Start Rod & Choke Rod
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Model G Start Rod & Choke Rod
    Posted: 15 Oct 2012 at 10:15am
Does anyone have a Model G with "original" Choke Rod & Start Rod?
I'm wondering if these two items used the same diameter rod material.
Best regards,
Scott
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 1:09pm
On my 48 g they are both same diameter. Can't imagine Allis using a different type of steel. On my B I used gas welding rod and made some.
jjrosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 2:44pm
my 48 g has a choke rod dia of .128 with paint &  the starter rod is .189 with paint
I have no way of knowing if they are original since its 10 years older than I am :)
If you always do, what you always did,
You'll always get, what you always got
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 4:10pm
They are different diameters. I made and sold several sets several years ago. I don't think I have any wire stock in one or the other diameters.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 9:48pm
It a great time to get wire for a rod for the G.
I used the wire that is used to support political signs they are placed all over the place before an election. I have found it in 2 sizes. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjrosty Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 8:26am
 I have used those signs that are corrugated plastic to hold bolts when tearing down machinery,  cut a slit push bolts in & write location on back.  then you can clean & paint all at once.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 10:40am
Scott,
I made these for the G that I finished in July. The choke rod was 1/8" diam. and the starter rod 3/16" diam. I bought steel stock at Tractor Supply. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 11:34am
From memory I have to agree with Dick L.  I recall that the starter rod was thicker than the choke rod.  Made sense since the starter was a harder pull than the choke.
Good Luck!
Bill Long
