Propane Tank Regulator
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Topic: Propane Tank Regulator
    Posted: 13 Oct 2012 at 10:22am
Is there an easy way to check a propane tank regulator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 11:16am
They measure in inches of water, most gauges will not go that low as regulated pressure is very low.  You may check with a propane distributor in the area if they have equipment to do sdo.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 11:36am
Call your supplier . If you have  a leased tank ..the first stage regulator  is your suppliers  responsiblity . Either way  the  second stage   is your baby .. When i worked in propane , we changed out both , routinely , especially the older one which didnt have the  attachements to do a wc test . Your supplier  will do this for you ..usually very reasonable .
Also , once they touch your system  they now assume liability , so it will be tested for leaks , according to current laws
Edited by michaelwis - 13 Oct 2012 at 11:38am
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
This page was generated in 0.963 seconds.
