HD4 Diesel Loader
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: HD4 Diesel Loader
    Posted: 13 Oct 2012 at 10:17am
The owner says it will only turn left sometimes. He also told me that it has hyd steering clutches. I know it is hard to diagnose a problem on the computer, but is there anything that would commonly go wrong with these units, and what it might take to fix it. Also what motor would this have in it, and approx year.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 10:29am
It could have pedal steer, but I thought that happened on the 650 series.Most likely steering clutches are worn. They are dry type clutches. Year would be late 60's. Engine is a 200 cu inch diesel. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 11:59am
655 had pedal steer / HD4 had lever steer , Turning a slow turn can be clutch only control but turning a hard turn uses the brake bands .
 Trying to see if it has hand clutches - looks like it might be upgraded as can not see levers.  As you step on the brake (light pressure) that track should stop driving and the machine slowly turn in the direction of applied brake. Stepping with full force should apply the brake as well as the clutch and machine should pivot on the locked track.
 Engine is AC 2200 series . 4 cylinder - was made in gas and diesel using the same components of block. Engine was used in fork trucks and Cotton pickers. In the cotton combine it used a turbo version and could put out up to 85 HP.
