C hydrolic pump seal
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: C hydrolic pump seal
    Posted: 12 Oct 2012 at 8:25am
My seal on my c has a steady leak do they make that seal still?
Can't fix stupid
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 9:08am
Where is it leaking Aj ? The pump housing or line?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 9:44am
Around the where the pump housing bolts up to the back of the tractor. Thinking of painting the tractor in the future but wanna fix all the leaks before hand.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 9:48am
I think Agco can still get you one but it's pretty easy to make it yourself. Mike
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 10:08am
Can you make it out of a sheet of gasket?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 11:35am
Yes or a shoe box lid or cereal box. Coat with a very little amount of gasket sealer and it should be good to go. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 1:09pm
Factory is bout the same as brown paper sack,maybe thinner.
