262 gas in D19, F questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: 262 gas in D19, F questions
    Posted: 30 Sep 2012 at 7:22pm
Was the gas engine in a D19 and the engine in a Gleaner F essentially the same engine other then the governor?   I've seen numerous people mention to use the Zenith carb off of the combine engine for pulling.   What's the difference between that engine and the one in the D19.   I picked up a Gleaner F engine this summer complete, and was wondering if the hp of that engine is more then my stock D19, and if I would be better off swapping the entire engines out.   Right now I know the head on my D19 engine needs some work, and I was thinking of pulling the head off that one and swapping them, but maybe I should switch out the entire engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:33pm
I would say essentially the same but not an expert.The combine engine will have a higher advertised HP because they are flwheel rated and tracors are pto rated. HTH Obviously the govs are different.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:49pm
I think the Gleaner C had the 262 engine in it.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:40pm
C and early F's then F's went to Chevy 292
