160 Advice
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: 160 Advice
    Posted: 30 Sep 2012 at 10:05am
I am thinking of getting a 160 in the future sometime because I believe it may be a good all around tractor.
1. What are the pros and cons of the 160?
2. Also, how common are the 460 loaders for them and is there other allis loaders for it?
3. What are the values of the 160's (pending the shape obviously)?
Can't fix stupid
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:03pm
Parts arte hard to get, I would stay away from them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:30pm
http://www.mainetractors.com/allis%20chalmers%20160%20tractor/allis%20chalmers%20160%20tractor.htm
Sold Part # 0 Allis Chalmers 160     (2) Used Price LBS
  2072636 A Air Cleaner Asy $75.00   2011
  2080138 A Camshaft $100.00   2011 31415260
  2080139 A Camshaft Gear $30.00 8 2011 50T
Sold 1   A Crankshaft $200.00
  2080095 A Crankshaft Gear $0.00
Sold 1  2080097 A Crankshaft Pulley $90.00   2011
  2080329 A Crankshaft Pulley $90.00   2011
Have 1 2080000 A Cylinder Block Diesel $500.00   2012 Perkins C3711210
Sold 1 2080000 A Cylinder Head $235.00   2011
  2080041 A Cylinder Head 235.00   2011
  2080110 A Cylinder Head Cover $20.00 3 2011
Sold 1 2080033 A Engine Mounting Bracket RH $45.00   2011
Sold 1 2080034 A Engine Mounting Bracket LH $60.00   2011
Sold 1 2080235 A Fuel Lift Pump $45.00
Sold 1 251315 A Fuel Filter Head & Base $65.00   2011
Sold 1 2080140 A Idler Gear $250.00   2011 0410134, 90T
Sold 1 2080274 A Injector Pump $400.00   2011
  31164440 A Injection Pump Drive Gear $55.00   2011 50T
Sold 1 2080071 A Manifold Exhaust $0.00
Sold 1 2080133 A Manifold Intake $45.00   2011
  2080206 A Oil Filter Canister $100.00   2011
Sold 1 2080177 A Oil Pan $240.00   2011 37171700
Sold 1 2080189 A Oil Pump Asy $80.00   2011
Sold 1 2080104 A Piston $50.00   2011
Sold 1 31337220 A Connecting Rod $50.00   2011
  2080120 A Rocker Arm Asy $55.00   2011
  2080145 A Timing Gear $.00
  2080163 A Timing Gear Cover $100.00   2011
  2080145 A Timing Gear Housing $80.00   2011
Sold 1 2080232 B Fan $30.00 4 2011
Sold 2 2073285 B Radiator $225.00   2011
Sold 1 2080215 B Water Pump Asy $65.00   2011 D9003715
  2072545 C Main Shaft 5th Gear $80.00   2011 32T
  2072546 C Pinion Shaft 5th Gear $155.00   2011 27T
  2072522 C Range Control Gear $95.00   2011 18T, 21 Splines
  2072548 C Main Shaft 6th Gear $80.00   2011 38T
  2072829 C Clutch Housing $155.00   2011
  2072846 C Clutch Housing Bearing Guide $50.00   2011
Sold 1 830641 C Clutch Release Bearing $100.00   2011
Sold 2 2073558 C Clutch Plate Asy $220.00
  2074250 C Clutch Shaft & Fork Asy $65.00   2011
  2072521 C Clutch Shaft $90.00   2011
  2072796 C Clutch Shaft $90.00   2011
  2072840 C Clutch Sleeve $70.00   2011
Sold 1   C Flywheel Adapter Plate $0.00
Sold All 2072960 C Flywheel Asy w/Ring Gear $370.00   2011
  2072693 C Flywheel Housing $105.00   2011
  2072548 C Pinion Shaft 6th Gear $135.00   2011 24T
  2072434 C Synchronizer Asy $105.00   2011
  2074390 C Pinion Shaft Sliding 3rd & 4th $190.00   2011 29T, 33T
Sold 1 2073509 C Reverse Gear $0.00
Sold 1 2072446 C Reverse Shaft $0.00
  2074399 C Range Control Lever $80.00   2011
Sold 1   C Shift Cover w/Forks $200.00   2010
  2072527 C Range Gear Shaft $65.00   2011
  2072525 C Range Gear Intermediate $70.00   2011 16T, 33T
  2074360 C Reverse Idler Gear $160.00   2011 13T, 15T
  2072511 C Range Gear $80.00   2011 36T, sn To 144400
  2072536 C Range Sliding Gear $230.00   2011 35T External, 18T Interior
  2072431 C Pinion Shaft Sliding Gear (1st & 2nd) $195.00   2011 37T, 41T
Sold 1 2072432 C Sliding Gear (3rd & 4th) $250.00   2011
Sold 1 2073943 C Sliding Gear (3rd & 4th) $250.00 3 2011 18T, 22T
  2073931 C Shift Fork 3rd & 4th $80.00   2011
  2073932 C Shift Rod 3rd & 4th $85.00   2011
Sold 1 2072401 C Transmission Housing $225.00   2011
  2074345 C Transmission Housing $225.00   2011
  2072413 C Transmission Input Shaft $650.00   2011
Sold 1 2074389 C Transmission Main Input Shaft $650.00 6 2011 21 Splines, 14T, 10T
  2072529 C Transmission Splined Coupling Sleeve $155.00   2011 6 External Splines, 21 Interior Splines
  2073846 D Hydraulic Reservoir $50.00   2011
Sold 1 2072605 D Hydraulic Manifold $265.00   2011
Sold 2 2074076 D Hydraulic Pump $250.00   2011
  2073320 D Hydraulic Oil Filter Asy $65.00   2011 sn To 144137
Sold 1 2072858 D Hydraulic Lift Housing $205.00   2011 sn To 145166
Sold 2 2072663 D Hydraulic Remote Valve Asy $370.00 12 2011
Sold 1 2073578 D Hydraulic Position Control Valve $520.00   2011 sn To 144400
Sold 1 2072805 D Lift Arm Asy Right $185.00   2012 Adj. RH Lift Link
  2073317 D Hydraulic Semi Adj. LH Lift Link $100.00   2012
Sold 2   D Draft Link $90.00   2012
Sold 1   D RH Lift Link $150.00   2012
Sold 1   D LH Lift Link $100.00   2012
  2074412 D Hydraulic Lever Arm $85.00   2011
  207855 D Lift Arm Right $60.00   2011
  2072982 D Hydraulic Sensing Arm RH $145.00   2011
  2074409 D Hydraulic Lift Arm RH $60.00   2011
  2072856 D Lift Arm Left $60.00   2011
  2074407 D Hydraulic Lift Arm LH $60.00   2011
  2072983 D Hydraulic Sensing Arm LH $145.00   2011
  2072858 D Lift Housing $205.00   2011 sn To 145166
  2072752 D Hydraulic Quadrant Support $60.00   2011
  2073572 D Lift Housing Plate $80.00   2011
Sold 1 2072869 D Piston $45.00   2011
  2073999 D Hydraulic Piston $45.00   2011 3.197"
  2072971 D Hydraulic Sensing Shaft $100.00   2011
  2072877 D Rockshaft, Lift Arm Shaft $0.00
  2073736 D Shaft & Pump Support $30.00   2011
  2073256 E Front Axle Asy $0.00
  2073168 E Front Axle Support $0.00
Sold 1   E Front End $0.00
Sold 1 2072551 E Front Axle Extension LH w Spindle $190.00   2011 270038
Sold 1 2072549 E Front Axle Extension RH w Spindle $190.00   2011 270038
  261418 E Front Hub $50.00   2011
Sold 1 2073328 E Power Steering Cylinder Asy $380.00   2011
Sold 2 2073327 E Power Steering Pump $220.00 12 2012 Casting # 34840,
Sold 1 2073363 E Power Steering Ram $0.00
  2072692 E Steering Arm LH $95.00   2011
  2073798 E Steering Arm RH $110.00   2011
Sold 1   E Steering Ram $0.00
  2073816 E Steering Shaft Asy $218.00   2011
Sold 1 2073737 E Steering Valve Asy $500.00   2011
  2073704 F Differential Asy w Ring & Pinion $650.00   2011
Sold 1 2073236 F Differential Bevel Gear $0.00
Sold 1 2073226 F Differential Housing $275.00   2011 sn Break = 2073948 141695 to 144799
  2073149 F Differential Housing Cover $70.00   2011
  2072826 F Final Drive Left Sleeve $205.00   2011
  2074873 F Final Drive Sleeve LH $205.00   2011
  2072828 F Final Drive Right Sleeve $205.00   2011
  2074428 F Final Drive Sleeve RH $205.00   2011
Sold 1 2072934 F PTO Drive Shaft Gear $155.00   2011 32T
Sold 1 2072838 F PTO Input Shaft $175.00   2011 sn To 143594, 10 Splines, 14T
Sold 1 2072943 F PTO Shaft Rear Interior Gear $0.00   2010
Sold 1 2072949 F Rear Axle $480.00   2011
  2072808 F Rear Axle Gear $140.00   2011
  2074427 F Rear Axle Gear $140.00   2011
Sold 1 2073610 G Fuel Tank $0.00
Sold 1 2073212 G Hood $0.00
  2073140 G Platform RH $60.00   2011
  2073139 G Platform LH $30.00   2011
  2072956 G Starter $110.00   2011
Sold 2 2073702 G Tachometer Asy $50.00
Sold 1   G Wire Harness $110.00
Sold 1 2073131 C Engine Frame Left Side $0.00
Sold 1 2073132 C Engine Frame Right Side $0.00
  2073546 H Brake Clevis Asy $85.00   2011
  2073623 H Brake Plate Asy $120.00   2011
  2073976 H Brake, Left Cover $70.00   2011 sn 141695 Up
  2073974 H Brake, Left Housing $190.00   2011 sn 141695 Up
  2073072 H Brake, Right Cover $70.00   2011
  2073975 H Brake Housing Cover RH $70.00   2011 sn 141695 Up
  2073065 H Brake, Right Housing $190.00   2011
  2073973 H Brake Housing RH $190.00   2011 sn 141695 Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:19pm
AWW they are nice tractors , very peppy and nice speeds , some parts are a little hard to get as they were made in France at the time - Agco has most and the others can be found from places here on the Internet ; 460 loaders are very common , alot of them out there , im really not sure the models that fit a 160 , but i know they had them , ive seen them from 2500 rough condition to 6500 for nice ones , if its decent running and decent tires , id say around 3500-4500 ; tires are a big factor now as they really have jumped up in price , overall there pretty tough good little tractors
