OT: Miss at low idle?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: OT: Miss at low idle?
    Posted: 30 Sep 2012 at 9:04am
I am looking at a Case 580D backhoe that has a miss at low idle only.  Runs fine at high idle.  It is a diesel engine, so I am thinking that the injector pump might need a rebuild.  No sign of excessive smoke from the muffler.
What do you think it needs?  Looks to be a good unit otherwise.
Thanks!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 9:17am
look at injectors first, if it's a Roosa pump it's not real common to lose just one cylinder. Possibly a pump problem, and servicing the pump and injectors would be a smart investment, if you can buy it right.
