Who makes this hyd pump?
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: Who makes this hyd pump?
    Posted: 29 Sep 2012 at 6:45pm
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 6:53pm
need numbers so can identify otherwise it was furnished by the loader manufacturer
  1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 6:57pm
Its a new idea loader.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 9:08pm
What does the tag on the pump say?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:08pm
Thats the first D-17 that I've seen with the optional factory auxillary hydraulic setup. I've seen it in the manuals. A-C used Barns small pumps, some Webster pumps and the industrial division used Cessna pumps. A good hydraulic shop should be able to repair or find an exact replacement.
Edited by Calvin Schmidt - 30 Sep 2012 at 8:11pm
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:54pm
I stole this pic from Russ in IA.
