WD 45 Transport valve
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Transport valve
    Posted: 27 Sep 2012 at 7:10pm
Do i need a transport valve on a WD 45 to use the traction boster with a semi mounted plow? plow book says it must have a transport valve. Dont have a book for a 45.
Thanks Randy
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:18pm
What is a transport valve, not familiar with that.Tongue
Tfanning View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tfanning Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:38pm
Yes, the transport valve is required.  It allows the front of the plow to come out of the ground before the rear.  Without it , the traction booster, when operating, will raise the back of the plow allowing it to swing out of the furrow towards the land away from the furrow.  You probably can purchase the valve, indicator and lines from a salvage tractor.
Tom
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 7:38pm
  y es you do need one to work sucessfully    we havsome new old stock   aaalso need the fixtures for instally    1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 8:04pm
You can replace the transport valve with a high pressure ball valve, then turn it on and off from the seat as necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 8:33pm
Uncle Theo,that would be very annoying even though effective. Gotta be better to round up parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 8:37pm
You could also drop the plow in the ground and then disconnect the hose to the rear cylinder till you got to the other end.LOL
llreckow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote llreckow Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 8:38pm
If your plow has a rear tailwheel you should use a transport valve. If your plow is fully mounted you do n ot need a transport valve.
