HD11 AC DOZER
RL@TLF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RL@TLF Quote  Post ReplyReply Direct Link To This Post Topic: HD11 AC DOZER
    Posted: 27 Sep 2012 at 2:01pm
I have an HD11 dozer, SN 5601E - I recently had the front cylinders
rebuilt and they work fine. However, I get unequal lift on the blade
and it makes it difficult to get an even cut. Is there any adjustment
on the hydraulic valves or pump controlling the cylinders to equalize
the lift? Thanks for any input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 2:08pm
Sounds like you have binding somewhere in the system of the blade itself , the cylinders should lift the same unless one has leakage , hyd pressure should equalize and if surface area is the same in both cylinders it should lift the same.
 Check your hoses or lines for restrictions both on the pressure side of lift and the release side or return line. Make sure the hoses or lines are not restriction flow in or out.
Edited by Coke-in-MN - 27 Sep 2012 at 2:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RL@TLF Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 1:59pm
Thanks Coke-in-MN, I'll take a look at all the lines.
I don't think I have any binding in the blade itself.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 9:27pm
Try adjusting the support brace/arms to the dozer blade, that will cause what you are describing.
