WD Help
Jim H(CO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim H(CO) Quote  Post ReplyReply Direct Link To This Post Topic: WD Help
    Posted: 24 Sep 2012 at 6:06pm
Have finally had a chance to tear into my WD.  Fixed the governor with the help of a friend, but it sounds like I have a bad exhaust valve now.  I have a 3 bolt WD45 that I had intended to rebuild, but in an effort to get the WD running have decided to use it for parts until I have the money and time to fix the 45 right.  In that light, can I use the head and valves from the 45 and use it on the WD to get the WD running good again?  am planning on checking the pistons and sleeves once I get it apart, but since the WD sits outside figured it would be better to have the head ready to put back on, rather than waiting for a couple days while the shop grinds the original head.  Will then take the WD head and use it on the 45 when I am able to work on it again.  thanks for all the help.  Jim
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 12:09am
yes, the WD/WD45 heads are interchangeable, in fact the later WDs began using the taller head that would eventually be used on the WD45 (with minor changes). I would put the WD45 head back on the WD45 when you get it running you'll be much happier
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2012 at 7:45am
depends on if that wd has a tall or the short head on it. If they are different you will need to change the pushrods and studs too.
