220 battery question
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Topic: 220 battery question
    Posted: 24 Sep 2012 at 11:01am
I have a 220 with 4 batteries, which all need replaced, would like to go down to just 2 on the left side, like my 210, do I have to do anything to eliminate those other 2 on the right side or can I just leave them out?  Thanks!   A.J.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 11:35am
I removed the cables that went to the right side on mine when I went to just two batteries on the left side.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 11:37am
All those batteries and connections can be a PITA. When it had four batteries the battery connection on our 220 was parallel from left box to right or in other words there was 12V from each side. Not sure if that is OEM as it had been dinked with quite a bit in the 'lectrical dept. If yours is that way you can operate it from one box by simply removing the batteries. Obviously you have to remove or at least kill the power to the not used cables in the RH box. You also need the best amp/hr rated batteries that will fit in your box if your going to use it in coild weather.  When I had to replace the batteries I went down to 2 myself but went a differant route than you propose.  I went with a single 4D battery on each side and am very happy with the results, the loss of cable and connection problems and the 220 spins over briskly.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 9:05pm
Two left side batterys only in My D-21, 210, 220 with no problems but they hibernate in the cold weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 9:17pm
My 220 was missing left batt cover when purchased and had 2 batterys over on the rt side.Got some tread plate and hardware store piano hinge and made a very handy tool box outa the left side.
 I also use group 31 batteries
Edited by SteveM C/IL - 25 Sep 2012 at 9:54pm
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 10:02pm
Two batteries should work fine, unless you are trying to start the old gal in below zero weather without any type of block heater.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 12:03am
Not exactly sure what you mean but original was positive cable running from each side all the way to starter.  In other words, a tractor with 4 batteries would have 2 cables attached at the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 6:37am
Yes, that is how ours was wired. Everything was jury rigged with tape and cheapo bolt on terminals.  We trashed all of it and ran new for the single 4D battery on each side all the way to the starter.
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 2:45pm
we only have 1   1000 cold cranking amp car battery and it starts just fine but we only use the tractor in the warm months in the winter it could be a whole another story
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 2:49pm
you could leave those other cables but you need to tape the ends up so they dont rub on anything metal to short your other batteries out. if your are going to run 2 batteries make sure both positives are hooked together on your batteries so it stays 12 volts otherwise you will end up with 24 volts.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 9:48pm
We run two 31 series truck batteries in our 220 and D21. The 210 came with one battery but will have two batteries when it is restored.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
This page was generated in 0.031 seconds.
