WD -WD45 hydraulics overflow
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: WD -WD45 hydraulics overflow
    Posted: 22 Sep 2012 at 3:31pm
On looking on another post I found this on Duey's website:
      TIP
If you tie up the rear lift arms, the cylinders stay full of oil. If you then fill up the hydraulic reservoir, be very careful if you lower the arms later. There is a vent for the hydraulic reservoir under the inspection plate under the starter (one of the little traps that AC engineering created.) (usually a brass elbow installed in a threaded hole) This vent will squirt any over filled oil directly onto the foot clutch!!! On my tractors, I have plugged this vent with a pipe plug. Then I drilled a hole and welded a pipe coupler in the inspection plate under the starter, at an angle, to miss the starter and installed a cylinder vent. The result is a dry clutch as oil fumes and any overfill are vented to the outside.
Duey
I have a WD with a Farmhand F19 loader on it. I am always afraid of over filling the hydraulics...Have any of you done what Duey is talking about and do you have photos to show??
Thanks
Pastor Mike
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 4:30pm
According to an original Allis WD 'Operating Instructions Manual'
you check the hydraulic oil level with the rams extended.
Quote " Keep filled to high mark on bayonet gauge with rams extended"
But if you have a loader installed, I think you  leave those rams retracted / lowered.
Gary
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 10:30pm
the top mark on the dipstick itself says "full with rams extended" but that is for lift arms only loader rams I think are longer so should have less oil in reservoir for when they retract?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 10:37pm
Full is full with the lift arms extended. it don't matter what else you hook up to the system. If you have a loader, you check the level with the lift arms extended and the loader down.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 10:39pm
my loader manual says add 1 extra qt. for the loader on a WD45.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
