3 point d-19 at FSR
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: 3 point d-19 at FSR
    Posted: 20 Sep 2012 at 9:32pm
Me and the father in law went to the FSR wednesday and checked out the tractors at the Buckeye allis lot. they all looked great, that was actuallt the first d21 i had ever seen in person(they are pretty scarce around here). But the one that caught our eye the most was the d-19. we have never seen a standard three point on one. would love to have that on ours, looks like maybe the lower bracket was taken from a 180? i meant to stop back and talk to the guys but got side tracked. maybe the owner is on the site and could shed some light on what he did.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 10:41pm
The later D-19's were sold with either Snap-Coupler or 3pt from the factory. The 3pt for a 190 is almost identical to a D-19 with the exception of the draft and position linkage. All of the heavy brackets, drawbar, lower tugs, and lift arms from a 190 will bolt/fit onto a D-19. If you have an early D-19 you can even change the lift housing from a 190 and have a place for the center link.
