WD transmission clutch
crawdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crawdon Quote  Post ReplyReply Direct Link To This Post Topic: WD transmission clutch
    Posted: 19 Sep 2012 at 1:50pm
When I release the foot clutch on my WD the transmission engages no matter if the hand clutch is forward or back. Never owned a wd, could any one suggest what the problem is? Thanks
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 3:16pm
It is either warped, stuck, adjusted too tight, or eliminated. It could also be that the shift collar is not disengaging the clutch. It should make a distinctive snap sound when it is disengaged. Some antique tractor pullers eliminate it for weight. Just some ideas. pull the plate off from under the battery box and check it out. With the tractor off engage and disengage the hand clutch lever. The plates should seperate. Also watch the linkages to be sure they are working.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 3:39pm
There is always some drag and the tractor will want to creep. If a light touch of the brakes stops it , your ok., if not you have hand clutch problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crawdon Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 4:30pm
Ted,
I did the brake thing and now it works maybe something was stuck. Thanks for the replys.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 8:12pm
PLEASE CHECK THE OIL
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2012 at 10:22pm
when you hae the cover off o the hand clutch,ck and se if all 6 pivot pins are still in place.1 pin missing will shut it down...
