HD-4 crawler loader
pattucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pattucker Quote  Post ReplyReply Direct Link To This Post Topic: HD-4 crawler loader
    Posted: 15 Sep 2012 at 1:16pm
Great loader but has leak from shuttle shift fluid up in housing does any one have experience with this and how to fix . Also for person with the HD-6 on what kind of trans fluid my manual saws type F
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2012 at 2:02pm
Torque converter uses Type A  Dextron fluid.
Finals and trany use gear lube.
HD4 is nothing like a HD6 , one is industrial machine other is Construction line
mickymcdee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickymcdee Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 4:22pm
Is there much difference between type A and F dextron?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2013 at 5:11pm
Main thing is the amount of friction used on the clutches in the automatic transmissions . how much difference it would make in the shuttle clutch friction plates ?
 Type A suffex A - it seems now has been re designated into new fluid specifications.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 8:31am
Where is it leaking?  I have a 653 with leaks around the shuttle control valve by the batteries that I have not been able to stop.  All new o rings and still it leaks bad.  Is this a common problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickymcdee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 10:37am
Thanks, our HD4 does have a distinct leak, but not out of control. We are using it to move snow, but too damn cold to figure where the leak is....spring is coming!
  However, I checked the fluid on the dipstick and it is more brownish than ATF fluid and seems like a bit heavier as well, so I'm a little concerned about adding the wrong fluid.
  Anybody got any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 1:00pm
On the leak on the control valve - the spool could be pitted or the bore worn enough to allow leakage - OR the "O" rings could be the wrong size . I put all new rings int omy control valves both on the shuttle and the bucket controls and had no problem with leaks after . Rather than buying the full kit to rebuild i just did the rings themselves. Make sure the material of the "O" ring is right material if you used other than AC rings .
 On the color of the ATF - if it is brown - time to change it as it is contaminated with either moisture, particles or the wrong fluid added at some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mickymcdee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 2:03pm
Thanks Coke!
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 2:40pm
Thanks Coke!  I did by the rings from Minn Par.  I should have measured things but was in a hurry!  Maybe I should just look for a replacement valve and test the shuttle pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 3:11pm
In some cases where a "O" ring will not seal it is because the recess into which it fits is to big and ring does not form right - a backer washer is used also to make sure ring fits properly . These are found mostly in hydraulic cylinders but can be used in other positions also. (washer is a composite material and fits into groove along with ring.)
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 3:21pm
Interesting suggestion.  Know of a good place to find used parts for these as you are relatively close to me.  I really need the linkages for the power steering clutches as I just have some cables in there now
