A matter of balance ? |
| Author | ||
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Topic: A matter of balance ?Posted: 12 Sep 2012 at 7:23pm |
Somehow I have came close to tipping over a crawler and have stood one up on end and also on a skidloader have tipped forward while loading a truck to have machine leaning against the box , but this ? afraid I might get a little more than scared.
Edited by Coke-in-MN - 12 Sep 2012 at 7:26pm |
| Sponsored Links | ||
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1010 |
Posted: 13 Sep 2012 at 1:36am |
One could wonder how long the machine stayed in that position.........would be so interesting to hear the operator's take on the whole thing.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 13 Sep 2012 at 4:35am |
Sometimes you need a delicate hand on the controls, on a big machine, and a modicum of common sense. Here is a picture of a guy who was not so lucky. If you hurl easily, do not click on the link. http://www.hondahookup.com/forums/showthread.php?123376-How-NOT-to-unload-a-new-cat-dozer-*Graphic-Death*
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 13 Sep 2012 at 7:54am |
In that first picture, if the operator were to lower the bucket an dump it, he would be back on 4 wheels. Maybe a little too fast if he didn't know how to "snitch" the controls.
michale34
Posted: 13 Sep 2012 at 8:27am |
that picture of that dozer remindes me of my dad hauling his 6g in the bed of a dump truck.
Eric B
Posted: 13 Sep 2012 at 2:33pm |
CTuckerNWIL
Posted: 13 Sep 2012 at 5:29pm |
If you got a dozer, you make your own ramps out of dirt.
Eric B
Posted: 14 Sep 2012 at 12:29am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 14 Sep 2012 at 8:17am |
Used to watch contractors load backhoes into dump trucks, scary if you had never seen before, also saw a 955 Cat slide into a foundation hole when a side wall collapsed ut it stayed upright, just had to have a separate crawler for aid to get back out(first pours were done), can be a pretty dangerous place to operate heavy equipment.
michale34
Posted: 14 Sep 2012 at 8:19am |
what he would do like u said make a ramp out of dirt but he would usualy haul a load of dirt or two first when he got there he would back up to a pile of dirt and raise the bed a little a back off
DaveKamp
Posted: 22 Sep 2012 at 11:51am |
That would've been my first impression, but on second thought, NO... ...because the situation that GOT him to that position, was having the bucket heavy... and if you look at it now... it's EMPTY. Attempting to lower it without having something to support the counterweight end, will result in the tail end coming down really, really fast, and really hard. There's probably a couple of other things at play here... notice the machine is steered hard to the left. it MAY be that the machine steered AFTER being lifted clear, but I kinda doubt it. I suspect the bucket was heavy, the load was high, and he turned the wheel hard and hit the brakes. One particularly challenging detail about a wheel loader, is that when the machine is straight-on, the value of the counterweight is very predictable- you can measure the distance between load and fulcrum, and fulcrum to counterweight, and balance the machine nicely... but when you crank the steering over hard, the counterweight's distance to the fulcrum point changes... it gets CLOSER to the fulcrum, hence, your capacity goes DOWN!!! Rather dangerous side-effect of the articulating loader's design. I think the last note I have here... is that many wheel loaders I've operated, did NOT have hydraulic down... they were gravity down... the only hydraulic downforce available, was uncurling the bucket... beyond that, it was sheer mass of the bucket doing the lowering. From a design perspective, this has some benefits- the hydraulic cylinders consist of rams whose rods can be essentially the full diameter of the piston, which results in a more rigid, stronger hydraulic ram design, simpler assembly, better seals, and a whole lot more strength in a lighter package. The real catch though, is that being the case, there's not only nothing to allow him to force the bucket down, there's nothing, aside from a little bit of suction in the piston seals... that prevents the arms from being raised. So he's in a world of hurt here. Considering the machine's age, I'd be surprised if it doesn't have kill switches for tipover safety... if so, that engine's shut down, and he's got no chance of restarting it... about all he DOES have... is either patience to sit and wait for help, or carefully climb out, and hope he gets far away before it changes attitude. |
Coke-in-MN
Posted: 22 Sep 2012 at 12:13pm |
When loading my HD4 into the back of my dump truck one day I made a pile of dirt and then walked the loader up that and supposedly into truck bed , machine settled the pile some and the track locked into lip of the box, NEXT thing that happened is machine walked up track to point machine was standing upright with loader facing straight up, me in seat yet but machine setting on fuel tank and hyd tank . Son ran over and pulled kill lever to shut down. It happened so fast I did not have time to react to anything but pull both steering clutches back to prevent it from flipping fully over.
First and last time i tried loading that machine into truck. Least the HD5 with the hand clutch you feel the machine and balance and is easy to load or unload, the torque converted just limits your control.
