price on pin and bushing turn |
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Topic: price on pin and bushing turnPosted: 12 Sep 2012 at 5:24pm |
i got a price for a turn on my hd5 pins and bushings. $350.00 per side plus bolts. does this seem reasonable or should i keep shopping around. they are 33 links and dry. i tried to work a deal to remove the pads and save money but he said it would be the same price. $20.00 for a master pin also. he said john deere 350 was same diameter but a little longer and could be cut. anyone have tracks turned lately?
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 12 Sep 2012 at 5:30pm |
sounds cheap to me. dad priced pins and bushings turned on Hd10 track a couple years ago and it was $1500 per side and we had to remove pads
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 12 Sep 2012 at 6:58pm |
The track bolts are extra right? When I bought track bolts they cost $175 per side. That is a lot of labor for $350 per side. Go for it.
dadsdozerhd5b
Posted: 12 Sep 2012 at 7:11pm |
he said a bolt and nut was $.60 each whic i thought was cheap. i can see larger tracks being more as they naturally are longer and take more force to push apart and together. was about $80.00 for 1 side of bolts as they only have to remove one side of bolts for the turn. thanks for the info.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 12 Sep 2012 at 7:48pm |
When they turn the pins and bushings they only remove one set of bolts and leave the pad on the other link , no reason to remove both sides.
Last set I had done was a few years back and ran $450 for labor , about the same price for bolts as you state. Then I had a large supply of larger bolts so I just traded with shop.
