hd5b dozer progress |
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Topic: hd5b dozer progressPosted: 12 Sep 2012 at 4:59pm |
i am making progress. i got the axle in, track frame and tracks back on but then had a setback. the right steering clutch was very hard to pull back and needed alot of brake to get it to stop. i had noticed last year while running it that i had mice living in it as they came out when i drove it. i thought i had gotten rid of them but i guess not. so, i put it in the shop and started tearing into it. lo and behold, mice were in there. the worst part of the clutch removal was removing the brake pins. neither would come out so the hot wrench took care of them. luckily, they did not get to the center of the clutch, just outside in the compartment but their pee froze up the slide for the throwout bearing and making it hard to pull back. at least i can reuse the clutch and drum. i am making stainless pins to stop the rusting. i will upload pics soon.
dadsdozerhd5b
Posted: 12 Sep 2012 at 5:14pm |
here are some pics
dadsdozerhd5b
Posted: 12 Sep 2012 at 5:17pm |
still trying to figure out the multiple pic thing. :)
dadsdozerhd5b
Posted: 12 Sep 2012 at 5:18pm |
one more. still can not figure out how to comment on each pic.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 22 Sep 2012 at 10:31am |
Seems the dang mice make a mess of everything , as the 3/4' hole for the case drain is on the bottom I am unsure of they come through that or come through by the hole into the case for the brake rod.
Dang things end up into everything and it doesn't take them long to move in whan something sets for a few days.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 22 Sep 2012 at 10:35am |
i hate them meeses to peeses!
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
shanksmare
Joined: 12 Nov 2017 Location: Washington Stat Points: 25 |
Posted: 01 Dec 2017 at 1:07pm |
So you cut the pin out and pulled the clutch out with the brake band? Mines stuck too so I guess that's my next step.
shanksmare
Posted: 04 Dec 2017 at 2:52pm |
I ended up taking the 4 bolts out of the brake band bracket because the brake pins wouldn't come out and have all the clutch bolts out, seems pretty solid to the drive wheels yet, mine didn't look nearly as rusted as yours so why wont it come free?
